Rayger 14 Posted August 4, 2019 Posted August 4, 2019 Under Settings, whenever you're in a subcategory (Home Screen, Playback, Subtitles, etc.), if you press Back, you're usually taken back to the Settings screen. However if you press Back while under Display, you're taken all the way back to the Home screen.
Rayger 14 Posted August 5, 2019 Author Posted August 5, 2019 This appears to only happen the the first time I use Theater after reinstalling.
