igeoorge 26 Posted August 5, 2019 Author Posted August 5, 2019 on the internal network had worked. But abroad did not work. Thanks again for the tips. Click to update changes and perform tests. Thank you friend
pir8radio 1313 Posted August 5, 2019 Posted August 5, 2019 on the internal network had worked. But abroad did not work. Thanks again for the tips. Click to update changes and perform tests. Thank you friend so you are working now? Good job! 1
igeoorge 26 Posted August 9, 2019 Author Posted August 9, 2019 Hi friendsI'm almost fixing my hair, trying to solve this problem.I always used Emby to convert my files. I like to use it.But these days I realized a problem.Some converted movies work on chromecast and some don't.Please, can anyone help me? While playing the file for chromecast, this message appears. I use the same method of converting for all movies. Some work and some don't.
Luke 42219 Posted August 9, 2019 Posted August 9, 2019 @@igeoorge I've merged your topics as they are discussing the same issue. Thanks.
igeoorge 26 Posted August 9, 2019 Author Posted August 9, 2019 Thank you friend. @@Luke I also thought to be the same problem, but it seems to be something simple that I do not understand how to solve. Could you see this last post and help me?
Luke 42219 Posted August 9, 2019 Posted August 9, 2019 Have you compared your configuration to @@pir8radio?
igeoorge 26 Posted August 9, 2019 Author Posted August 9, 2019 Yes, I compared. @@Luke The problem is not in the settings because chromecast works. The problem is in playback, because as said, some movies play and some do not. I always use Emby to convert and always convert all files the same way. Choose the "mobile" and put in the "custon" and leave it at 3.2 mb / s This is a description of how it's time to convert by Emby.
pir8radio 1313 Posted August 10, 2019 Posted August 10, 2019 Yes, I compared. @@Luke The problem is not in the settings because chromecast works. The problem is in playback, because as said, some movies play and some do not. I always use Emby to convert and always convert all files the same way. Choose the "mobile" and put in the "custon" and leave it at 3.2 mb / s This is a description of how it's time to convert by Emby. what format are the ones that do not play? mp4?
igeoorge 26 Posted August 10, 2019 Author Posted August 10, 2019 All in mp4. The ones that don't work and the ones that work, I can both watch anywhere but not on chromecast.
igeoorge 26 Posted August 10, 2019 Author Posted August 10, 2019 Today has stopped working completely. I didn't change anything, I didn't change anything. And today it doesn't work at all. Does not work by browser or application. Always the same message as the photo.
pir8radio 1313 Posted August 11, 2019 Posted August 11, 2019 Today has stopped working completely. I didn't change anything, I didn't change anything. And today it doesn't work at all. Does not work by browser or application. Always the same message as the photo. sounds like your config is missing: proxy_set_header Range $http_range; ## Allows specific chunks of a file to be requested. proxy_set_header If-Range $http_if_range; ## Allows specific chunks of a file to be requested.
igeoorge 26 Posted August 11, 2019 Author Posted August 11, 2019 @@pir8radio Where can I include this? I use windows 10 as a server.
pir8radio 1313 Posted August 11, 2019 Posted August 11, 2019 @@pir8radio Where can I include this? I use windows 10 as a server. Oh yea you do not use nginx, just cloudflare right? You can't on the free cloudflare. So do these same mp4 files play on chromecast without cloudflare? or with it bypassed?
igeoorge 26 Posted August 11, 2019 Author Posted August 11, 2019 (edited) Hi I would like to use nginx but I am not knowledgeable enough. Accessing the server through HTTPS, chromecast appears to play, but you don't have to play any files. Then chromecast appears to play, but when playing, the initial image of the post appears. Edited August 11, 2019 by igeoorge
igeoorge 26 Posted August 11, 2019 Author Posted August 11, 2019 Hi @@pir8radio When you have free time could you help me with this problem? Thank you so much friend
pir8radio 1313 Posted August 11, 2019 Posted August 11, 2019 Hi @@pir8radio When you have free time could you help me with this problem? Thank you so much friend Not sure i can. I have no way to test or troubleshoot.
igeoorge 26 Posted August 11, 2019 Author Posted August 11, 2019 I entered your server with the test user and realize that there works perfectly. How can I apply the settings you recommended?
igeoorge 26 Posted August 11, 2019 Author Posted August 11, 2019 Hi @@pir8radio All right? I'm asking @@darkassassin07 for help setting up NGINX. You could say where I owe it for this proxy_set_header Range $http_range; ## Allows specific chunks of a file to be requested.proxy_set_header If-Range $http_if_range; ## Allows specific chunks of a file to be requested.
