bronder 0 Posted August 3, 2019 Posted August 3, 2019 (edited) I just installed Emby Sever and paid for a month of premier (looking to get off of Plex), but it won't update EPG data. It finds my HD Homerun and I am choosing the correct provider. If I hit refresh the status bar goes from 0 to 100 in a few seconds and nothing is loaded. I looked at the logs from the UI and see the below. Out of curiosity I also installed this on my 2nd server and have the exact same experience. The HD Home Run does have channels loaded as well so that discovery call returns 100's of channels if I just put the URL into a browser. 2019-08-03 10:26:55.372 Info HttpClient: GET http://192.168.1.9/discover.json2019-08-03 10:26:55.394 Info HttpClient: GET http://192.168.1.210/discover.json2019-08-03 10:26:55.427 Info HttpClient: GET http://192.168.1.211/discover.json2019-08-03 10:26:58.355 Info LiveTV: Discovered tuner device HD Homerun at http://192.168.1.92019-08-03 10:26:58.355 Info LiveTV: Discovered tuner device HD Homerun at http://192.168.1.2102019-08-03 10:26:59.782 Info HttpClient: GET http://192.168.1.9/discover.json2019-08-03 10:26:59.790 Info HttpClient: GET http://192.168.1.9:80/lineup.json2019-08-03 10:26:59.889 Info LiveTvManager: Refreshing guide with 7 days of guide data2019-08-03 10:26:59.899 Info LiveTV: Loading live tv data from C:\Users\plex\AppData\Roaming\Emby-Server\programdata\data\livetv\seriestimers2019-08-03 10:26:59.910 Info TaskManager: Refresh Guide Completed after 0 minute(s) and 4 seconds2019-08-03 10:26:59.924 Info TaskManager: ExecuteQueuedTasks Edited August 3, 2019 by bronder
Luke 42237 Posted August 3, 2019 Posted August 3, 2019 Hi there, did you setup guide data in Emby Server?
bronder 0 Posted August 3, 2019 Author Posted August 3, 2019 Yes, I setup the guide data. Followed the wizard. Chose my zip, provider, and then specific lineup ( WOW - Columbus Digital) or something like that.
Luke 42237 Posted August 3, 2019 Posted August 3, 2019 Did you check the mapping tool to make sure that your tuner channels are mapped to guide channels?
bronder 0 Posted August 3, 2019 Author Posted August 3, 2019 That's the thing I guess I didn't convey. Emby doesn't even show channels.
bronder 0 Posted August 3, 2019 Author Posted August 3, 2019 So.. i added and removed the tuner a few times and added the guide back a few times and now it's magically delicious. You can mark this as closed unless you want something from my end (logs) to debug on why the issue was happening.
Luke 42237 Posted August 4, 2019 Posted August 4, 2019 Thanks for the feedback. If you want to attach the emby server log I can answer that.
