Juw 4 Posted August 2, 2019 Posted August 2, 2019 Hi, I was on the emby tizen app installed via usb when i get the message on launch « new version available » So.... i go to the github, i download the new tizen.zip, i extract to my usb key, i remove the emby app from my tv but when i plug the usb the installation dont start.... i can just explore the key and when i go to the folder usrwidget the folder is empty ... Can you help me ? My tv: UE55RU8000S Thx
FrostByte 5453 Posted August 2, 2019 Posted August 2, 2019 (edited) You sure you deleted before inserting the USB? Or did you just remove from Home? Edit: maybe try power cycling the TV after deleting old version Edited August 2, 2019 by FrostByte
Juw 4 Posted August 2, 2019 Author Posted August 2, 2019 You sure you deleted before inserting the USB? Or did you just remove from Home? Edit: maybe try power cycling the TV after deleting old version Thank you for the answer, My bad, i forget to remove from the apps and i just remove from home, im so sorry, thank you its ok now 1
FrostByte 5453 Posted August 2, 2019 Posted August 2, 2019 Oh good, because I was all out of ideas after that
Betelgeuse 14 Posted August 8, 2019 Posted August 8, 2019 I upgraded without uninstalling the old first. Seemed to work. Before Emby Server said I was connected with Emby Theater 1.0.62; after upgrade it says connected with Emby Theater 1.0.63. So, uninstall first doesn't seem necessary?
Luke 42241 Posted August 8, 2019 Posted August 8, 2019 I upgraded without uninstalling the old first. Seemed to work. Before Emby Server said I was connected with Emby Theater 1.0.62; after upgrade it says connected with Emby Theater 1.0.63. So, uninstall first doesn't seem necessary? Some users have reported that when the app is already installed, that inserting the usb drive will not do anything. So we added it to the instructions just to be sure. 1
FrostByte 5453 Posted August 8, 2019 Posted August 8, 2019 (edited) I upgraded without uninstalling the old first. Seemed to work. Before Emby Server said I was connected with Emby Theater 1.0.62; after upgrade it says connected with Emby Theater 1.0.63. So, uninstall first doesn't seem necessary? Were you using the usb version before and upgraded that? I can upgrade the store version to usb, but not old usb version to new usb version What year TV do you have? Edited August 9, 2019 by FrostByte
Betelgeuse 14 Posted August 9, 2019 Posted August 9, 2019 (edited) Were you using the usb version before and upgraded that? I can upgrade the store version to usb, but not old usb version to new usb version What year TV do you have? I used the USB version downloaded from github before and after. My TV is UE55KU6075 from 2017. Edited August 9, 2019 by Betelgeuse 1
FrostByte 5453 Posted August 9, 2019 Posted August 9, 2019 Great, thanks. Might be an issue with 2018 and 2019s only then 1
FrostByte 5453 Posted August 9, 2019 Posted August 9, 2019 I've modified the USB instructions a little so that people can try to upgrade, but if it won't upgrade to delete the previous version first. 1
Betelgeuse 14 Posted August 9, 2019 Posted August 9, 2019 I don't remember if I mentioned before, but I would appreciate the version number in the file name at github. Also please publish the USB instruction there as well. 1
Luke 42241 Posted August 9, 2019 Posted August 9, 2019 The instructions will ultimately be moved to our website. That's the only place they need to be. 1
