BAlGaInTl 288 Posted August 8, 2019 Posted August 8, 2019 (edited) Out of curiosity, what's your network look like? Are you playing wireless? Is it possible that Emby is negotiating a direct play initially, and then the network is degrading? ETA It seems odd to me that you are seeing the same behavior on multiple files and multiple systems. Edited August 8, 2019 by BAlGaInTl
kuebs 6 Posted August 9, 2019 Author Posted August 9, 2019 In the case of this particular Roku player, it is wired. I can try things other than AVI files. Most, but not all MKV files work. But not all. And they used to. Same goes for playing personally recorded home videos. I used to be able to play them through the Emby Roku app, and not I cannot. They all pixelate. Something has changed. I am just not sure what and if it is on the Roku/Emby side, or on my side. But its to the point where I am starting to consider alternatives. We just want to be able to play the movies without a lot of hassle. Much like the TV it is replacing. Someone mentioned converting AVIs to MKVs I believe. How is that done? Is there an automated way to do that?
kuebs 6 Posted August 9, 2019 Author Posted August 9, 2019 Can you try something other than an avi file? Thanks. I could, but many of these older movies are only in the AVI format.
Luke 42216 Posted August 9, 2019 Posted August 9, 2019 Have you checked out our media conversion feature? This can help you automate converting those Avis into a more streaming friendly format: https://emby.media/community/index.php?/blog/1/entry-423-emby-server-34-released/
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 Thanks for asking. I was, but now I have bigger problems. I think I was on to a solution with uninstalling codecs and going with some different codec solutions. But now I can't seem to run emby, or when I get it running, I can't log into it with my roku devices. I tried to configure it on the server console, but I can't seem to get in. As if I don't have permissions now. And I tried to do a reinstall of the latest embyserver download and now I can't install. It says my security settings won't allow me to run the program and I have run it as administrator. I have no idea what is going on, but I am ready to throw up my hands.
Luke 42216 Posted November 25, 2019 Posted November 25, 2019 Do you still have your previous installation? What happens when you try to start the server?
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 i can sometimes get into the console. Sometimes now. After a few reboots I can get to the console. where I made a second account and was sure of that password, also I made sure of the original account password, and I cannot get into the WMC instance of Emby or Roku with either account. Each time it says wrong password. While the same account/PW works fine through browser access.
Luke 42216 Posted November 25, 2019 Posted November 25, 2019 i can sometimes get into the console. Sometimes now. After a few reboots I can get to the console. where I made a second account and was sure of that password, also I made sure of the original account password, and I cannot get into the WMC instance of Emby or Roku with either account. Each time it says wrong password. While the same account/PW works fine through browser access. Are you running the latest Emby for WMC beta? You need to be on that for the new version of the server.
Luke 42216 Posted November 25, 2019 Posted November 25, 2019 4.3.0.26 That's the version of the server. What about Emby for WMC?
Luke 42216 Posted November 25, 2019 Posted November 25, 2019 Ok, then i would suggest installing the beta from our website on top of your existing version: https://emby.media/emby-for-windows-media-center.html
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 @@Happy2Play I tried. now we are back to my other problem. I can't install it. I am prevented. It says my security settings will not allow it.
Happy2Play 9806 Posted November 25, 2019 Posted November 25, 2019 @@Happy2Play I tried. now we are back to my other problem. I can't install it. I am prevented. It says my security settings will not allow it. What exactly are your getting?
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 A windows error that says, "Your security settings do not allow this application to be run on your computer"
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 i may have found a fix. https://superuser.com/questions/1252575/unable-to-install-clickonce-application-due-to-security-settings-windows-10 some kind of trustmanager prompting level that was set to disabled, in the registry. 1
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 and I was able to install the beta version. And I was able to login with my old account and its password. So the beta seemed to fix the issue. Thanks.
kuebs 6 Posted November 25, 2019 Author Posted November 25, 2019 Now, next and hopefully last issue, before I can get back to the playback issues. Now when I log in through WMC I get prompted for an account and also the password. Prior to this point, I only had to click on the account and the account loaded in, as if the password was saved. I also still have the second account, but I am using the original account, which is what the Rokus are set for.
Luke 42216 Posted November 25, 2019 Posted November 25, 2019 Great, thanks ! Are you still having an issue on Roku?
ebr 16313 Posted November 25, 2019 Posted November 25, 2019 Now, next and hopefully last issue, before I can get back to the playback issues. Now when I log in through WMC I get prompted for an account and also the password. Prior to this point, I only had to click on the account and the account loaded in, as if the password was saved. I also still have the second account, but I am using the original account, which is what the Rokus are set for. Hi. Please try this.
kuebs 6 Posted November 26, 2019 Author Posted November 26, 2019 OK. I am trying that. It took me a bit to find those settings. Thanks. Another interesting note, is that in Beta, I now have an odd representation of the shows under my videos. In the previous version, I would be able to browse and see a listing of all the shows/series and could sort them by date and by alpha. Now I get these views, latest, upcoming, new. But I cannot browse the series. I can't figure out how to fix that.
kuebs 6 Posted November 26, 2019 Author Posted November 26, 2019 I think that this is mostly resolved. Now i can go back to troubleshooting the playback issues.
Luke 42216 Posted November 26, 2019 Posted November 26, 2019 Thanks, we're happy to help with your playback issues.
Luke 42216 Posted January 21, 2020 Posted January 21, 2020 @@kuebs are you still having playback issues?
