rechigo 367 Posted July 31, 2019 Posted July 31, 2019 I installed the auto box sets on my new server and it isn't generating all my box sets, it only generated one. It should be generating the same ones that were generated on my old server, but for whatever reason it only generated one.
Luke 42219 Posted July 31, 2019 Posted July 31, 2019 Hi there, can you please go over an example? Have you consulted our AutoBoxSets wiki article to learn what is required in order for collections to be created?
rechigo 367 Posted August 1, 2019 Author Posted August 1, 2019 They all had the collection ID in the metadata, but for whatever reason it's working fine now. Thanks anyways for the tip
rechigo 367 Posted August 2, 2019 Author Posted August 2, 2019 Following up this post, I have figured out that auto boxsets doesn't automatically create/modify the sets, it will only do it if I call it manually from the plugin center
ebr 16314 Posted August 2, 2019 Posted August 2, 2019 Following up this post, I have figured out that auto boxsets doesn't automatically create/modify the sets, it will only do it if I call it manually from the plugin center Hi. Why do you think that is the case? It will run during a library scan.
Happy2Play 9806 Posted August 2, 2019 Posted August 2, 2019 Note it does not run on a individual library scan. Requires Library-Scan All/Scheduled task library scan. Not positive how much logging is only in debug logging. 2019-08-02 02:02:56.403 Debug App: Running post-scan task CreateBoxSetsTask 2019-08-02 02:02:56.525 Info Auto Box Sets: Executing Automatic BoxSet creation. Found 508 potential box sets.
rechigo 367 Posted August 2, 2019 Author Posted August 2, 2019 I scanned all libraries using the scan libraries button on the server dashboard. I will test this again to double check when I add more media in a couple days, i will follow up with amotger reply
Luke 42219 Posted August 3, 2019 Posted August 3, 2019 Note it does not run on a individual library scan. Requires Library-Scan All/Scheduled task library scan. Not positive how much logging is only in debug logging. 2019-08-02 02:02:56.403 Debug App: Running post-scan task CreateBoxSetsTask 2019-08-02 02:02:56.525 Info Auto Box Sets: Executing Automatic BoxSet creation. Found 508 potential box sets. Yes this is correct.
