AYEHAN 2 Posted July 31, 2019 Posted July 31, 2019 hi, i have my server on windows 10 and the latest update installed is it possible to show Movie Quality i.eWeb-DL WebRip BRRip BluRay DvD etc etc on Movie Poster
ebr 16314 Posted July 31, 2019 Posted July 31, 2019 Hi. The CoverArt plug-in can put a resolution overlay on your images as well as use different cover types for SD, HD, UHD.
AYEHAN 2 Posted July 31, 2019 Author Posted July 31, 2019 (edited) when i installed it said trial expired, never let me test it so i make my mind of buying any subscription sorry it was some other plugin ok configured it as per my desire but how do i make it work, should i update metadata or what? Edited July 31, 2019 by AYEHAN
Luke 42221 Posted July 31, 2019 Posted July 31, 2019 You'll need to configure the cover art plugin to show indicator overlays if that is what you prefer.
AYEHAN 2 Posted August 1, 2019 Author Posted August 1, 2019 i did set indicator overlay, but on emby main page i see nothing happened
Luke 42221 Posted August 1, 2019 Posted August 1, 2019 i did set indicator overlay, but on emby main page i see nothing happened What exactly did you set? What type did you set it on?
AYEHAN 2 Posted August 1, 2019 Author Posted August 1, 2019 @@crusher11 nop i have no subscription, @@Admin will send screen shot
amektura4000 0 Posted August 1, 2019 Posted August 1, 2019 (edited) Cover Art only works with Premiere.pornjk.com redtube porn600.me is it possible to show Movie Quality i.eWeb-DL WebRip BRRip BluRay DvD etc etc on Movie Poster Edited August 2, 2019 by amektura4000
Luke 42221 Posted August 1, 2019 Posted August 1, 2019 Not those kinds of qualities, but more general ones like hd.
Happy2Play 9806 Posted August 1, 2019 Posted August 1, 2019 I believe the only options are DVD, Bluray and 4K.
AYEHAN 2 Posted August 2, 2019 Author Posted August 2, 2019 means coverart wont work for Free users thank You @@Admin you can close the thread now
