Guest Posted July 30, 2019 Posted July 30, 2019 After using auto box-sets for a short test, "collections" appeared on my homescreen in the web- and ios-app. How to delete this? Before it showed only "TV shows" and "Movies" as I wanted.
Luke 42255 Posted July 30, 2019 Posted July 30, 2019 Hi there ,have you explored your emby user home screen settings?
KratosShield 0 Posted August 16, 2019 Posted August 16, 2019 (edited) I had installed the Auto Box Sets plugin and did not like the way it looked so I uninstalled it, however the collections are still there. How can I get rid of the collections? I want to manually create my own collections. I have restarted the server, signed out/in and scanned. Thanks in advance. I got it! Just removed them from appdata, problem solved. Edited August 16, 2019 by KratosShield
Luke 42255 Posted August 16, 2019 Posted August 16, 2019 How can I get rid of the collections? Use the functions in the interface to delete them.
