levander 97 Posted July 30, 2019 Posted July 30, 2019 Emby somehow managed to create three instances of same library this time. It happened to me many times before when I would click OK button more than once but this time I clicked it only once and the result is I have one library listed in dashboard and three instances of that same library on home screen. What should I do?
Luke 42221 Posted July 30, 2019 Posted July 30, 2019 It must have somehow registered multiple clicks, even though we do have some protection about that, it may still need to be hardended. The recovery process is the same as you did before. Remove them all, then run a library scan to flush out the database. Then add it back.
levander 97 Posted July 30, 2019 Author Posted July 30, 2019 It must have somehow registered multiple clicks, even though we do have some protection about that, it may still need to be hardended. The recovery process is the same as you did before. Remove them all, then run a library scan to flush out the database. Then add it back. Did that + restarted emby = it has been removed from in dasboard but there is still one instance left on home screen! What now?
