Solution Luke 42216 Posted August 3, 2019 Solution Posted August 3, 2019 It's more likely that by renaming it was no longer associated with anything in the database related to the old paths. Thanks for the feedback. Let us know how you get on. You said you came from a really old version and going from version 3 to version 4 there were some upgrade related issues with dvd folder structures. I'm afraid that given the very small audience for folder rips nowadays, ultimately these were left as-is and required manual fixing by removing and then re-adding to the library. 1
Taffer 0 Posted August 4, 2019 Author Posted August 4, 2019 All working fine now but it was a bit of a process Steps I took in the end to fix the problem Rename each folder with the first aired date in brackets ie Lexx (1997) That was not enough to fix everything so I went into each folder and deleted anything that was not a folder ie images or metadata all the way down to the Video_ts folder I also deleted every metadata folder in each season Ran a complete library scan and Emby picked up everything and created new nfos
Luke 42216 Posted August 4, 2019 Posted August 4, 2019 Thanks for the feedback. Apologies for the disruption.
Chris Able 0 Posted February 5, 2020 Posted February 5, 2020 Hi, I have the same issue. Last weekend, I did some space management, so I moved few folder on another drive and than my seasons were not there. Just tried the rename the folder and after scanning all my libraries, everything went back. I'm on version 4.3.1.0. I'll fix it by renaming all my folder but if it is possible to have another solution for the next time, it would be great. Thanks
Luke 42216 Posted February 5, 2020 Posted February 5, 2020 Hi, I have the same issue. Last weekend, I did some space management, so I moved few folder on another drive and than my seasons were not there. Just tried the rename the folder and after scanning all my libraries, everything went back. I'm on version 4.3.1.0. I'll fix it by renaming all my folder but if it is possible to have another solution for the next time, it would be great. Thanks We'll look into why that may have happened. Thanks for the feedback.
