Luke 42240 Posted December 8, 2019 Posted December 8, 2019 @@LongMan that's great info, thanks for taking the time to write that up.
LongMan 116 Posted December 28, 2019 Posted December 28, 2019 We have work out some kinks and new test test builds of the MediaImport branch is available here. https://forum.kodi.tv/showthread.php?tid=224794&pid=2911447#pid2911447 After installing, go to Settings>Addons>Install from Zip file. (It should prompt to enable Unknown sources, enable it and go back to install the zip file, using zip file obtained here. https://github.com/Montellese/mediaimporter.emby There are no settings for the addon itself so there is nothing to configure there. Now go to; Settings>Media Sources>All Media Providers/Actice Media Providers (Either should work).You should see your server here, sign in.If not, choose Add Provider…, then choose ‘EMBY’, and add the URL of your server (http(s)://ipaddress:port) If your server is found, a dialog will pop up allowing you to enter and test your credentials. Do so and click ok. If authenticated, your server will now appear as a provider after the dialog closes. Choose it and choose Add Imports… . You should see the media types available there. Choose one, a dialog should pop up which allows you to choose what libraries are imported and synchronized. The default is All, for importing all libraries of that media type. However, the setting can be changed to choose, enabling you to select which libraries are imported from the multiselect dialog that appears. Having selected your library, or libraries, choose Ok. Synchronization should begin immediately. There is also a Synchronize Tab which allows to edit what info is synchronized but the defaults are best be left as is for testing. You can then return to Kodi’s Home screen and play whatever item has been imported. You do not have to wait for the import process to be completed. Feedback would be greatly appreciated. As you can guess, when you are working on something for a long time, there might be little things that you overlook, or labels that should have been changed overtime but have not been and so are not as specific as they could be.Give it a spin and say what you think about it Thanks in advance, LongMan @@Luke, I wasn't sure if I should re-post here or, start a new thread with an introduction to MediaImport in the Kodi section of the forum
Luke 42240 Posted December 29, 2019 Posted December 29, 2019 Feel free to start a new thread in the Kodi section as it might get more attention that way. Thanks.
