davedick 19 Posted July 30, 2019 Posted July 30, 2019 When I do a search for "BULL" the show does not appear in the results. Also when I search for Michael Weatherly, NCIS shows up, but not Bull
davedick 19 Posted December 7, 2019 Author Posted December 7, 2019 Sorry for the delay. I forgot that I asked this question. This is a show that is on CBS on Monday's at 10 pm. When I search for "bull", nothing comes it's, but in the channel guide it's listed as "bull"
davedick 19 Posted December 7, 2019 Author Posted December 7, 2019 The magnifying glass on the top right. I have attached a pic showing the show in the channel guide, but this won't show up under "programs" in the search results Hi. Exactly where are you searching?
ebr 16332 Posted December 7, 2019 Posted December 7, 2019 I just did a search for "Bull" and came up with a couple of results. Is it simply an issue of there are so many results for you that maybe it is too far down the list? What is your guide provider?
davedick 19 Posted December 7, 2019 Author Posted December 7, 2019 I just did a search for "Bull" and came up with a couple of results. Is it simply an issue of there are so many results for you that maybe it is too far down the list? What is your guide provider? I'm not seeing many shows titles that contain bull in the results
Luke 42237 Posted December 7, 2019 Posted December 7, 2019 can you show a screenshot of the search results? thanks.
davedick 19 Posted December 7, 2019 Author Posted December 7, 2019 can you show a screenshot of the search results? thanks.So the bull that's listed in from my library. The rest are the results from programs results
Luke 42237 Posted December 8, 2019 Posted December 8, 2019 OK so ebr is right. Search is limited to a certain amount of results and it looks like it just got pushed down to the bottom of the list under Programs. We plan to revamp the search UI in future updates to improve this. Thanks.
