RogerK 9 Posted July 29, 2019 Posted July 29, 2019 Since I upgraded to Server 4.2.0.40 any collection that has another collection as a member does not show the included collection. I also had several collections that were completely composed of other collections that are not showing any more but still exist in the collections repository (emby-server\programdata./data/collections) Looking at the collection xml file the embedded collections are still included there but do not show in any app.. I have done a library scan, restarted emby server, and tried rebooting the sever. Is there a known issue or anything else I can try to resolve this? Also as another item in the browser (chrome) and android apps the collections library not long shows the alphabet navigation down the side of the screen. The Roku app still has the alphabet navigation.
Luke 42219 Posted July 29, 2019 Posted July 29, 2019 Hi, we've had to remove this for now as nesting collections is just not ready to be in the production release. android apps the collections library not long shows the alphabet navigation down the side of the screen. It does have the a-z picker, but only when you sort by tittle. Can you please check that? thanks.
RogerK 9 Posted July 29, 2019 Author Posted July 29, 2019 It was set to sort by title but I switched to something else and then back. The alphabet navigation still was not there in either chrome or android. However in the android app when I switched to another sort the left border of the screen got much thinner and then got thicker when I switched back to title order it expanded like it should to show the alphabet but it wasn't displayed.
RogerK 9 Posted July 29, 2019 Author Posted July 29, 2019 Sorry I put left side of screen but it was the right side that expanded
Luke 42219 Posted July 31, 2019 Posted July 31, 2019 Can you show a screenshot? I don't see any problem here, sorry. The A-Z picker is showing up just fine, but again, it will only be there when sorting by title. Thanks.
RogerK 9 Posted July 31, 2019 Author Posted July 31, 2019 Here are screenshots from chrome and android
Luke 42219 Posted July 31, 2019 Posted July 31, 2019 The first screen is expected behavior. At lower vertical resolutions we hide the picker due to not having enough space.
