EatPrilosec 22 Posted July 28, 2019 Posted July 28, 2019 (edited) Ive got three GPUs in my server; an intel hd 3000, ati radeon 5570, and a gtx 680. The hd3000 doesnt show up in emby, so I'm not sure if it actually does anything which is no problem, but I'm curious to see which devices are doing what in real time. Is there a way to tell which device is transcoding (and if possible which device is doing the decoding / which is doing the encoding?)A command line option would suffice, but i have half a mind to put this as a feature request for "stats for nerds" if its possible Also, there is the possibility that the CPU is doing the transcoding, would that show up as "mode: Transcode (software)" or something like that? Edited July 28, 2019 by NErdgOd56
Luke 42246 Posted July 29, 2019 Posted July 29, 2019 Hi, you can already tell between CPU vs. GPU based on the hardware icons, but yes, listing the specific GPU i think is a good idea for the future. thanks.
