vdatanet 1619 Posted July 31, 2019 Posted July 31, 2019 What is the audio bitrate? Stream #0:1: Audio: ac3, 48000 Hz, 5.1(side), fltp, 384 kb/s (default)
Guest asrequested Posted July 31, 2019 Posted July 31, 2019 (edited) Reading this again, it appears as though downmixing is isn't being done correctly. What audio options does your TV have? Does it have an option to process the sound to a pseudo surround sound? What is your TV doing with your audio? Edited July 31, 2019 by Doofus
mad_cow 2 Posted August 1, 2019 Author Posted August 1, 2019 Um, actually I have no idea what audio options my TV has. But I found another AC3 media file in my library, which plays fine TitleEnglish Dolby Digital 5.1 TaalEnglish CodecAC3 Opmaak5.1 Kanalen6 ch Bitrate640 kbps Samplesnelheid48.000 Hz StandaardNo and the file where I get an issue with the audio stream TitleDolby Digital 5.1 (Default) CodecAC3 Opmaak5.1 Kanalen6 ch Bitrate384 kbps Samplesnelheid48.000 Hz StandaardYes I attached the server log when I played the other AC3 file which works fine embyserver_otherAC3file.txt
Guest asrequested Posted August 1, 2019 Posted August 1, 2019 Check your audio settings. https://helpguide.sony.net/gbmig/C5241001/v1/eng/index_622_334.html
mad_cow 2 Posted August 1, 2019 Author Posted August 1, 2019 My TV's sound setting are: Dual Sound: Stereo Speakers: TV Speakers Sound Mode: [standard]: Optimises sound quality for general content. Sound Booster On Advanced Auto Volume Off I dont see any setting that appears to be upmixing the surround sound
Guest asrequested Posted August 1, 2019 Posted August 1, 2019 Well, if other similar audio plays correctly, I'm wondering if the channel arrangement it wrong. I have an anime like that. The voice is on the front right channel etc. I keep meaning to fix it, but I forget about it. Can you share the file?
vdatanet 1619 Posted August 1, 2019 Posted August 1, 2019 The strange thing is when transcoding is downmixed fine, so channel arrangement should be ok. We definitely need a sample to take a look.
Guest asrequested Posted August 1, 2019 Posted August 1, 2019 The strange thing is when transcoding is downmixed fine, so channel arrangement should be ok. We definitely need a sample to take a look. Yeah, it's a weird one. But if the channels are wrong, depending on how it's downmixed, it could omit some channels and give the output he's describing. He has sound, but it's the wrong sound.
mad_cow 2 Posted August 10, 2019 Author Posted August 10, 2019 What's an appropriate way of sharing my file?
mad_cow 2 Posted August 17, 2019 Author Posted August 17, 2019 Here's a link to the media files and the subtitle files that accompany it. https://www.dropbox.com/sh/x4hm72rbpqpyp2d/AAC8rP4ifvDt2xiX8aP01XZfa?dl=0
Guest asrequested Posted August 17, 2019 Posted August 17, 2019 I think I see the problem. The file header is saying that the audio is only 2 channel AC3, but ffprobe is reading the actual media correctly as 6 channels. There might be a simple fix.....
Guest asrequested Posted August 17, 2019 Posted August 17, 2019 (edited) Yeah, that's the problem. If I leave the audio set to auto, it plays correctly. But If i set it downmix to stereo, you only get the extraneous audio. Edited August 17, 2019 by Doofus
Guest asrequested Posted August 17, 2019 Posted August 17, 2019 Unfortunately, the info is embedded, and I haven't found a way to correct it
Guest asrequested Posted August 17, 2019 Posted August 17, 2019 Someone with good knowledge of ffmpeg could probably give you a command line that would decode and re-encode it. I can do that in mpv, on playback.
mad_cow 2 Posted August 19, 2019 Author Posted August 19, 2019 Thanks for looking into this. Good to see that it is a media issue and not a bug.
