bluemonkey07 590 Posted July 27, 2019 Posted July 27, 2019 after upgrading to the latest server release i lost about half of my live tv channel guide info. upon inspection i found that they were no longer mapped, i tried to remap them in the server dashboard but there still seems to be some issue as the setting does not have any affect. server is freenas if that makes any difference is this a known issue?
Luke 42244 Posted July 27, 2019 Posted July 27, 2019 Hi, no, there weren't any reports of this in beta. Did you try refreshing the guide? I would do that first, and then try using the channel mapping tool after that. Let me know if this helps. Thanks.
bluemonkey07 590 Posted July 27, 2019 Author Posted July 27, 2019 yes i did a refresh of everything after updating
Luke 42244 Posted July 27, 2019 Posted July 27, 2019 So what exactly happens when you use the mapping tool?
bluemonkey07 590 Posted July 27, 2019 Author Posted July 27, 2019 before remapping: remmapped: after guide refresh:
bluemonkey07 590 Posted July 27, 2019 Author Posted July 27, 2019 (edited) sbs hd Edited July 27, 2019 by Vidman
Luke 42244 Posted July 29, 2019 Posted July 29, 2019 how many tuners and guide sources have you created? are you sure the xml data isn't changing from one refresh to the next?
bluemonkey07 590 Posted July 29, 2019 Author Posted July 29, 2019 (edited) 1 hd homerun 1 guide source (ice tv) I'm pretty sure mapping a new channel triggers a guide refresh Edited July 29, 2019 by Vidman
bluemonkey07 590 Posted July 30, 2019 Author Posted July 30, 2019 Any clues? Do you need logs? xml data?
Luke 42244 Posted July 31, 2019 Posted July 31, 2019 I don't see anything obvious here and this works just fine in my testing. so yes that would help. Thanks.
bluemonkey07 590 Posted July 31, 2019 Author Posted July 31, 2019 I don't see anything obvious here and this works just fine in my testing. so yes that would help. Thanks.you have access to icetv guide data?
bluemonkey07 590 Posted July 31, 2019 Author Posted July 31, 2019 (edited) logs: i restarted the server, tried to map a few channels then exited which triggered a guide refresh emby-server.txt Edited July 31, 2019 by Vidman
Luke 42244 Posted August 2, 2019 Posted August 2, 2019 Can you provide a copy of the xml for testing?
Luke 42244 Posted August 5, 2019 Posted August 5, 2019 How do you have it configured in emby server? Is it pointing to that text file, or a url?
Luke 42244 Posted August 7, 2019 Posted August 7, 2019 @@denz are you using the mapping tool to map icetv channels to your tuner?
denz 501 Posted August 8, 2019 Posted August 8, 2019 Certainly do I used it last month when a new channel appeared. It is not something that you need to do that often here.
denz 501 Posted August 8, 2019 Posted August 8, 2019 I can install a stable server to see do I get the same issue as the person above.
Luke 42244 Posted August 8, 2019 Posted August 8, 2019 I am not able to reproduce. The only explanation i can think of is that the xml data is changing from one refresh to the next and that's why the channel name is missing from the mapping.
denz 501 Posted August 8, 2019 Posted August 8, 2019 I installed the portable stable version and I couldn't reproduce the issues that the poster is experiencing the only issue discovered is that three channels had the correct guide data but not the logos. I deleted the images and done the guide refresh and it downloaded the correct logos.
bluemonkey07 590 Posted August 8, 2019 Author Posted August 8, 2019 ok so i tried changing a working channel and it seems that channel mapping has no effect at all so i have a theory. when i updated i created a new jail in freenas and pointed the configuration to the same location as the old version, maybe they have different user id so the new jail doesn't have permission to alter this config file? (thou i don't seem to have issues anywhere else)
Luke 42244 Posted August 8, 2019 Posted August 8, 2019 It's possible, but we should see an error in the server log when saving if that is the case
bluemonkey07 590 Posted August 8, 2019 Author Posted August 8, 2019 It's possible, but we should see an error in the server log when saving if that is the caseoh ok
