Probando123 0 Posted July 27, 2019 Posted July 27, 2019 Buenas tardes, Me he encontrado un problema con la última versión (4.2.0.40) relacionada con el orden en el que muestra los títulos. Todos los archivos que empiecen por un símbolo de exclamación (¡) o interrogación (?) no es capaz de ordenarlos y salen siempre al principio. La solución momentánea a este "problema" es borrar ese símbolo del título, ya que en inglés no se usa.
Luke 42239 Posted July 27, 2019 Posted July 27, 2019 Hi there, do these titles have a custom sort order applied?
Luke 42239 Posted July 29, 2019 Posted July 29, 2019 Sorry i meant do they have a custom sort title in the metadata editor?
Probando123 0 Posted July 29, 2019 Author Posted July 29, 2019 No, todo por defecto, emby recién instalado y hace eso.
jaikel gutierrez 1 Posted November 4, 2019 Posted November 4, 2019 @@Happy2Play @@cayars Greetings open a way to simultaneously activate all the movies the item to avoid changes in the future and not do it manually one by one since I have about 600 movies? I have ordered some movies with their metadata and poster correctly but sometimes I see that emby changes the images and metadata in some movies.
Carlo 4561 Posted November 8, 2019 Posted November 8, 2019 I'm not sure how you can edit multiple movie titles at the same time? Unfortunately while some other items could possibly be edited in bulk the movie title would not be multiple edited.
vdatanet 1619 Posted November 8, 2019 Posted November 8, 2019 (edited) Yo no modifico el título de la película, yo suelo cambiar el campo "Clasificar por título", que es el título que se utiliza para la ordenación, campo que no se modifica en la actualización de metadatos, entonces no hace falta bloquear ningún campo: Edited November 8, 2019 by vdatanet
Luke 42239 Posted November 17, 2019 Posted November 17, 2019 @@jaikel gutierrez Has this answered your question?
jaikel gutierrez 1 Posted December 29, 2019 Posted December 29, 2019 Saludos soy jaikel gutierrez desde Venezuela. Pregunto ¿habrá alguna forma de configurar a cada usuario desde el servidor en que reproduzca las películas por defecto a una velocidad por ejemplo 480p – 720 Kbps y que no se coloque en auto. he notado que las películas cuando la empiezan a reproducir comienza en auto y empieza por la más alta calidad del video, y como tengo a clientes vía wifi la reproducción se les pega a cada momento por la alta calidad en video que tiene…sé que se puede configurar manualmente en la opción de ajustes del video pero eso tiene que hacerlo cada cliente desde su computadora o dispositivo, por eso sería bueno uno mismo como administrador hacer esa configuración en el servidor y en mi caso colocarlo a que ruede el video en 480p – 720 Kbps con esa resolución los videos se ven bien y no pesan mucho y dado a eso no se pega el video. Espero su respuesta gracias.
Luke 42239 Posted December 30, 2019 Posted December 30, 2019 @@jaikel gutierrez Hi, if it's on the same local network as your server then it will have to be done individually within each app. For remote streams you can set the remote streaming bitrate limit under the server's Network settings. Please let us know if this helps. Thanks
