lithium1978 0 Posted July 27, 2019 Posted July 27, 2019 I run my M3U through Xteve to filter out channels append proper channel numbers. I checked the filtered M3U and the tvg-chno fields are in the proper ascending order. However when I get into Emby and go to channel mapping they seem to be mapped randomly. Everything works but it's a bit of a hassle finding the channels. Any idea how I can get these in order by channel number?
Spaceboy 2573 Posted July 27, 2019 Posted July 27, 2019 I run my M3U through Xteve to filter out channels append proper channel numbers. I checked the filtered M3U and the tvg-chno fields are in the proper ascending order. However when I get into Emby and go to channel mapping they seem to be mapped randomly. Everything works but it's a bit of a hassle finding the channels. Any idea how I can get these in order by channel number?i would hazard a guess that you are using 3 digit channel numbers. If you are matching up channels and epg in xteve you can use any channel numbers you want. If you are using emby epg 3 digit numbers are reserved for internal use but if you use 4 digit numbers it should be fine
