macstainless 0 Posted July 25, 2019 Posted July 25, 2019 (edited) I'm new to Emby so I'm hoping this is a simple fix. I installed the server on my Mac and then the TWIT, LazyMan, and Trailers plugins into the respective folders. I restarted the server app but when it comes back up, nothing is visible for me to use. When I go into the admin section and view the installed plugins, they are there. Nothing is shown on the front-end at all. I've run into an almost identical situation found in this thread here ( Help playing plugins ) but there's no posted resolution. To help speed things up, I've attached my server logs below. ANY help on this would be appreciated as Plugins are the main reason I'm looking to use Emby. Thank you! Logs.rtf Edited July 25, 2019 by macstainless
Luke 42255 Posted July 25, 2019 Posted July 25, 2019 Hi there, where are you looking? Did you check the server plugins section? You can learn more on our plugins wiki: https://github.com/MediaBrowser/Wiki/wiki/Plugins Thanks.
macstainless 0 Posted July 25, 2019 Author Posted July 25, 2019 Hi there, where are you looking? Did you check the server plugins section? You can learn more on our plugins wiki: https://github.com/MediaBrowser/Wiki/wiki/Plugins Thanks. I've checked in the folder with the path: (My Home Directory)/.config/emby-server/plugins. The plugins are all showing there. I've attached some screen shots of the front end and back end along with my Finder window to help with any other questions. And yes, I did check that page you linked to but it provides no answers to this situation.
Luke 42255 Posted July 26, 2019 Posted July 26, 2019 Looks like they are there. I don't know what lazyman does so i can't really help much with that. For Twit, I would suggest checking your emby user permissions and make sure your user is granted access to that channel.
macstainless 0 Posted July 26, 2019 Author Posted July 26, 2019 (edited) Looks like they are there. I don't know what lazyman does so i can't really help much with that. For Twit, I would suggest checking your emby user permissions and make sure your user is granted access to that channel. Where would I check the user permissions, aside from the server Dashboard --> Users? When I check my user profile in the System dashboard, everything is checked except 'disable user' and when I go to the Access tab, 'allow access to all libraries' is checked too. There are no other options provided. LazyMan is a video streaming plugin, if that helps. Edited July 26, 2019 by macstainless
Luke 42255 Posted July 26, 2019 Posted July 26, 2019 Ok please try updating to the latest version of Emby Server, 4.2. Thanks.
macstainless 0 Posted July 26, 2019 Author Posted July 26, 2019 Ok please try updating to the latest version of Emby Server, 4.2. Thanks. That did it! I have no idea why the main emby page is serving a prior version of the app, but the Channels now show. Thank you. Weirdly, the TWIT channel is completely blank when I try to play something, but I'm guessing that's a plugin issue more than anything else. TuneIn half works, so there's some sort of functionality. Appreciate your help so far on this.
Luke 42255 Posted July 26, 2019 Posted July 26, 2019 Thanks for the feedback. I think the twit plugin needs some attention.
