Luke 42233 Posted August 19, 2019 Posted August 19, 2019 Emby for LG 1.0.18 has been released. Stay tuned to our blog for the announcement. Thanks.
Luke 42233 Posted October 25, 2019 Posted October 25, 2019 Emby for LG 1.0.19 has been released. Stay tuned for the release announcement on our blog.
sfboender 4 Posted October 26, 2019 Posted October 26, 2019 @@Luke, new update which was pushed this week is again causing issues with the ass subtitles. Moment you select it, emby crashes.
sfboender 4 Posted October 26, 2019 Posted October 26, 2019 See references like Dr.Stone from Horriblesubs or Assassins Pride. Basically all content i checked is causing the crashes.
SamES 1084 Posted October 26, 2019 Posted October 26, 2019 @@Luke, new update which was pushed this week is again causing issues with the ass subtitles. Moment you select it, emby crashes. Is this case on both your C7 and C8?
sfboender 4 Posted October 26, 2019 Posted October 26, 2019 Only updated on the C8 dont want to have the situation likr last time where both tvs cant playback the content
macnb 32 Posted October 26, 2019 Posted October 26, 2019 (edited) @@Luke, new update which was pushed this week is again causing issues with the ass subtitles. Moment you select it, emby crashes. Yup same problem for me too on the LG B9. Need to check a bit more as it does not happen with all the movies. But definitely fails with Dynasties TV Show. The ASS file was created from the SRT file using my SRT2ASS FFMPEG script. I am only using ASS because the Emby on LG cannot change the size, font, colour, etc of the SRT subtitles. UPD: Crashes Emby player every time with all the files I tried. Edited October 26, 2019 by macnb
cinescore 0 Posted October 26, 2019 Posted October 26, 2019 I can confirm the crashes happen with my LG C9 as well. I tried 3 different TV shows and the player crashes when the first subtitle line is supposed to be rendered. The .ass files were created from SRT files using Subtitle Edit 3.5.10. With the previous version and the same episodes I had no crashes.
alucryd 318 Posted October 26, 2019 Posted October 26, 2019 The workaround described earlier doesn't work either, external .ass files also crash the app on the C9.
sfboender 4 Posted October 27, 2019 Posted October 27, 2019 (edited) Checked friends B8 and also issue, workarounds dont work just like the last release. @@Luke any thoughts, because wasn’t this fixed previously? Last version did have an issue where the content wouldn't play directly but after 1-2 min waiting it would play. Annoying but still was something but compared to 4 versions ago where content would play directly it would be great if we had a permanent fix for this either direct play or waiting. Thanks as always for your efforts and that of the team. Edited October 27, 2019 by sfboender
Luke 42233 Posted October 27, 2019 Posted October 27, 2019 Looks like there's an issue only with WebOS4+ that we'll need to get an update out for. Thanks.
dnanielsen 8 Posted October 29, 2019 Posted October 29, 2019 Can someone running WebOS 3 with firmware 05.30.60 confirm that external .ass subtitles are still working on Emby 1.0.19? I don't want to update and break this support.
SamES 1084 Posted October 29, 2019 Posted October 29, 2019 Can someone running WebOS 3 with firmware 05.30.60 confirm that external .ass subtitles are still working on Emby 1.0.19? I don't want to update and break this support. I've tested this with 3 or 3.5 and it's fine, but no harm in waiting until the next version to be sure, unless there is another feature you need in a hurry. I expect the next release should come quickly 1
sfboender 4 Posted November 3, 2019 Posted November 3, 2019 @@Luke any ETA on the new update? Half of my media are now unplayable thanks again for your efforts!
Luke 42233 Posted November 19, 2019 Posted November 19, 2019 Emby for LG 1.0.20 has been released. Stay tuned for the release announcement on our blog.
sfboender 4 Posted November 19, 2019 Posted November 19, 2019 @@SamES @@Luke still doesnt work. 3 seconds of playback and emby stops. After 3 attempts Emby app crashes!
SamES 1084 Posted November 20, 2019 Posted November 20, 2019 @@SamES @@Luke still doesnt work. 3 seconds of playback and emby stops. After 3 attempts Emby app crashes! Thanks, that's unfortunate. I'll see what's happened as this was working, but not for long it appears.
SamES 1084 Posted November 20, 2019 Posted November 20, 2019 Just checked and this release is working for me. @@sfboender or @@alucryd, could you PM a link to a file I can test with? Thanks
sfboender 4 Posted November 22, 2019 Posted November 22, 2019 Just send you a PM. Hope you and @@Luke can figure out what the issue is.
wblcx 1 Posted November 23, 2019 Posted November 23, 2019 I have the same problem. I could provide a file with this problem if needed.
