Pain 13 Posted July 25, 2019 Posted July 25, 2019 Been having this issue for a while now. When watching a recorded TV show the program will lock up freeze and then get a message something like to many errors. Attached is the log.. Thanks embyserver.txt ffmpeg.txt
Luke 42242 Posted July 25, 2019 Posted July 25, 2019 Hi there, what Emby app are you playing with? Does it always happen in the same spot of the video?
Pain 13 Posted July 25, 2019 Author Posted July 25, 2019 Hi @@Luke Fire TV Stick. Yes it happens at the same spot every time I try to watch it... I have 1 Emby tuner setup with HDHR. And a couple IPTV tuners as well...
Luke 42242 Posted July 25, 2019 Posted July 25, 2019 What about if you play with a different app, such as the web app?
Pain 13 Posted July 25, 2019 Author Posted July 25, 2019 Web app plays it but there was a hiccup at the same point but played passed it. Also if i FF the Fire TV past that spot it plays but missed a few seconds to a minute. At lest on this one program it does...
Luke 42242 Posted July 26, 2019 Posted July 26, 2019 Ok please try the new 4.2 server release with new recordings. Thanks.
Solution Pain 13 Posted August 3, 2019 Author Solution Posted August 3, 2019 @@Luke @@softworkz After upgrading Emby all seems good now.. Haven't had a recording issue at all. Lets hope I didn't speak to soon lol. Thanks for all the hard work you all put in to Emby.. It only gets better from here... Thanks 1
connieda 0 Posted August 21, 2019 Posted August 21, 2019 (edited) Running Emby on ds218+,Emby on Synology Premium 4.2.1.0 , HDHR Quatro, Nvidia Shield 4K. All equipment was new and I setup this up back in Feb 2019. Everything worked perfectly until I updated Emby a few weeks ago. Now I get clicking and then it freezes and start pixilating the playback and recordings. Once this starts I have to reboot Emby. Then it will work for a while sometimes as long as a day. I have several scheduled recordings a day. When the issue starts it will display the issue on recordings, live tv playback on the Sheild and from my windows Emby client. I can open the HDHR app and live TV is working fine. It started on the previous update and I have applied the 4.2.1.0. The H264 encoding preset is set to 23. After the issue started Shield had an update available so I applied that. I also download a new version of HDHR software and installed that. One thing to note every time I reboot Emby I see a message pop up in Yellow Please reboot Emby to apply updates, but there is nothing showing in package center as an available update. Rebooted everything several times, NAS - Shield. I have attached all logs from /var/packages/EmbyServer/target/var/logs Edited August 21, 2019 by connieda
Luke 42242 Posted August 21, 2019 Posted August 21, 2019 Running Emby on ds218+,Emby on Synology Premium 4.2.1.0 , HDHR Quatro, Nvidia Shield 4K. All equipment was new and I setup this up back in Feb 2019. Everything worked perfectly until I updated Emby a few weeks ago. Now I get clicking and then it freezes and start pixilating the playback and recordings. Once this starts I have to reboot Emby. Then it will work for a while sometimes as long as a day. I have several scheduled recordings a day. When the issue starts it will display the issue on recordings, live tv playback on the Sheild and from my windows Emby client. I can open the HDHR app and live TV is working fine. It started on the previous update and I have applied the 4.2.1.0. The H264 encoding preset is set to 23. After the issue started Shield had an update available so I applied that. I also download a new version of HDHR software and installed that. One thing to note every time I reboot Emby I see a message pop up in Yellow Please reboot Emby to apply updates, but there is nothing showing in package center as an available update. Rebooted everything several times, NAS - Shield. I have attached all logs from /var/packages/EmbyServer/target/var/logs Hi there @@connieda, let's look at an example. Please attach the information requested in how to report a media playback issue. thanks !
connieda 0 Posted August 22, 2019 Posted August 22, 2019 More logs logged in user Connie, Time 5:42 Mountain log upload, Issue 5:00-5:35 AM 8-22-2019 - reboot 5:35 AM
connieda 0 Posted August 30, 2019 Posted August 30, 2019 Hi I uploaded logs on 8/22 and no reply, issues still happening I am having to reboot daily to fix temporarily
Luke 42242 Posted November 1, 2019 Posted November 1, 2019 @@connieda, we'll be releasing Emby Server 4.3 very soon. Please try again with that once available. Thanks.
