Guest Posted July 23, 2019 Posted July 23, 2019 Hi, I would like to have a CSS code to get the main menu images as close as possible.Thank you
Guest Posted July 23, 2019 Posted July 23, 2019 I would like to ask what is the ideal size for the menu images? I use 1600x900px and would like to know if it has another ideal size better suited for various emby applications.
Happy2Play 9811 Posted July 30, 2019 Posted July 30, 2019 Something like this. This targets a specific section. #homeTab div.section0 div.cardBox {margin: 0em; }
Guest Posted July 30, 2019 Posted July 30, 2019 (edited) Hi,This is another code that works well in 4.1 and broke in version 4.2.Thanks so much for your help correcting this code.If it is not possible to eliminate the top stripe, I would like to make it transparent to merge with the homepage backuground/* Remove top stripe from login screen - NOT WORKING */ div.skinHeader.skinHeader-withBackground.headroom.noHeaderRight {display:none; } Edited July 30, 2019 by CarlosLima
Guest Posted July 30, 2019 Posted July 30, 2019 (edited) Sorted out.I chose to apply a transparent background to the top bar.Thank you Edited July 31, 2019 by CarlosLima
Happy2Play 9811 Posted July 30, 2019 Posted July 30, 2019 Hi, This is another code that works well in 4.1 and broke in version 4.2. Thanks so much for your help correcting this code. If it is not possible to eliminate the top stripe, I would like to make it transparent to merge with the homepage backuground /* Remove top stripe from login screen - NOT WORKING */ div.skinHeader.skinHeader-withBackground.headroom.noHeaderRight {display:none; } Commented in other topic, but it would appear ".noHeaderRight" has been removed so I personally don't see a way to target that location specifically without affecting other areas.
