Luke 42243 Posted July 22, 2019 Posted July 22, 2019 Hi there, have you set your emby user subtitle preferences? this is what the download feature uses.
casperse 0 Posted July 22, 2019 Posted July 22, 2019 Hi there, have you set your emby user subtitle preferences? this is what the download feature uses. Yes like this: So I thought that it would download the MKV file with the SRT file, but it seems that only MKV files with the SRT included works? Is this correct? if I set Burn subtitles it would have to transcode all files before coping them to my device wich would slow down the process allot...
Luke 42243 Posted July 23, 2019 Posted July 23, 2019 Sorry I don't quite understand. Can you please go over an example? Thanks.
