Cinema Mode 1.0.21 has bug with Emby 4.2.0.30-beta Synology (DS918+)
@@Luke
Trailers never be played. It worked before in some previous version.
2019-07-20 20:42:54.755 Error App: Error getting intros
	*** Error Report ***
	Version: 4.2.0.30
	Command line: /volume1/@appstore/EmbyServer/releases/4.2.0.30-beta/EmbyServer.dll -package synology -programdata /var/packages/EmbyServer/target/var -ffmpeg /var/packages/EmbyServer/target/ffmpeg/bin/ffmpeg -ffprobe /var/packages/EmbyServer/target/ffmpeg/bin/ffprobe -ffdetect /var/packages/EmbyServer/target/ffmpeg/bin/ffdetect -restartexitcode 121
	Operating system: Unix 4.4.59.0
	64-Bit OS: True
	64-Bit Process: True
	User Interactive: True
	Runtime: file:///volume1/@appstore/EmbyServer/3rdparty/netcore/2.2.1/runtime/System.Private.CoreLib.dll
	Processor count: 4
	Program data path: /var/packages/EmbyServer/target/var
	Application directory: /volume1/@appstore/EmbyServer/releases/4.2.0.30-beta
	System.NullReferenceException: System.NullReferenceException: Object reference not set to an instance of an object.
	   at Emby.Server.CinemaMode.DefaultIntroProvider.GetIntros(BaseItem item, User user)
	   at Emby.Server.Implementations.Library.LibraryManager.GetIntros(IIntroProvider provider, BaseItem item, User user)
	Source: Emby.Server.CinemaMode
	TargetSite: Void MoveNext()
embyserver.txt
Just tested, Cinema Mode 1.0.10 does work with Emby 4.2.0.30-beta Synology
Weird, after uninstall 1.0.10 and install again 1.0.21, now it works.
Case closed
