Guest worthington_j Posted July 19, 2019 Posted July 19, 2019 What is the difference if any between a repair libraries on all libraries vs. performing a local database reset?
Solution Angelblue05 4132 Posted July 19, 2019 Solution Posted July 19, 2019 The reset will wipe the database completely. The repair will remove entries from the selected libraries and re-add them.
