sundevil67 30 Posted July 17, 2019 Posted July 17, 2019 I'm not sure how much the screenshot helps, but for some reason, the system automatically creates a 'collection' for these 2 movies even though they are not technically related other than the fact that they have the same name in the title: 1) Enter the Ninja 2) Revenge of the Ninja Don't judge me for my bad taste in cheesy 80's ninja movies I keep deleting the collection, only to have it show up again the next day. Any idea what's happening here? server_log.txt
Luke 42210 Posted July 17, 2019 Posted July 17, 2019 Hi there, did you check MovieDb to see if this is listed there?
Solution Happy2Play 9802 Posted July 17, 2019 Solution Posted July 17, 2019 The "AutoBoxSets" plugin gets the collectionid from the metadata as TMDB has them as part of the collection. https://www.themoviedb.org/collection/373538-enter-the-ninja-collection If you don't want them as a collection you will have to remove the collectionid from the item metadata and lock the metadata, then delete the collection via the UI. 1
Luke 42210 Posted July 18, 2019 Posted July 18, 2019 I'm not sure how much the screenshot helps, but for some reason, the system automatically creates a 'collection' for these 2 movies even though they are not technically related other than the fact that they have the same name in the title: Hi, the "system" gets this information from MovieDb. Based on that, why do you feel that it's a problem?
sundevil67 30 Posted July 23, 2019 Author Posted July 23, 2019 Thanks so much for trying to help! Mea culpa - I blew it this time & Emby was correct! So sorry - my ninja-movie memory isn't what it used to be & I'd actually forgotten the details related to this franchise. The 2nd movie was technically a sequel even though it ignores the first chapter & has a different cast...It's one of those random one-offs in a franchise like Friday the 13th V, Fast and Furious 3, etc. Anyway, case closed. Thanks anyway
scf 0 Posted October 3, 2020 Posted October 3, 2020 I don't have the Auto Box Set plugin installed, and I'm still getting collections I don't want. How do I fix this?
Happy2Play 9802 Posted October 3, 2020 Posted October 3, 2020 1 hour ago, scf said: I don't have the Auto Box Set plugin installed, and I'm still getting collections I don't want. How do I fix this? Can you go over a specific example and the server log of when it happened if possible.
scf 0 Posted October 3, 2020 Posted October 3, 2020 I don't see a log. The specific case was a group of three movies: "Bulldog Drummond Escapes (1937)", "Bulldog Drummond's Peril (1938)", and "Bulldog Drummond's Revenge (1937)". I removed them from the collection and deleted the collection, but have no idea how the collection was created in the first place.
Carlo 4561 Posted October 3, 2020 Posted October 3, 2020 It will be in the logs. Do you have other uses on your system? Quite possibly one of them created the collection.
scf 0 Posted October 4, 2020 Posted October 4, 2020 No other users, just me. The only items I see in the logs show the removals: cat * | grep Bulldog 2020-10-03 00:38:07.865 Info App: Removing item from database, Type: BoxSet, Name: Bulldog Drummond, Path: /Users/scf/.config/emby-server/data/collections/Bulldog Drummond [boxset], Id: 26683 2020-10-03 00:38:07.866 Info App: Deleting path /Users/scf/.config/emby-server/data/collections/Bulldog Drummond [boxset]
