deecemobile 3 Posted July 16, 2019 Posted July 16, 2019 (edited) Hi guys, big thanks to all who have posted walk throughs for setting up domains, DDNS, SSLs, etc. So far I have the domain name and DDNS working for HTTP traffic. But for whatever reason HTTPS traffic just times out everytime. I am relying on the UPnP protocol on my router instead of port forwarding and the bindings are correct. 443 is going to 8920, 80 goes to 8096. But I cannot connect via https:// or :443 ever. Even setting up manual port forwarding does not work. So I cannot tell if my certificate is even working but I shouldn't need the certificate to even connect via HTTPS, right? If the port binding is there I should be able to connect I am using Certify the Web for the SSL and it has been correctly setup with my domain but I can't tell if Emby is really using it. Any help would be appreciated. Edited July 16, 2019 by deecemobile
Luke 42221 Posted July 16, 2019 Posted July 16, 2019 Hi, did you configure your certificate in the advanced section of the server?
deecemobile 3 Posted July 16, 2019 Author Posted July 16, 2019 Hi, did you configure your certificate in the advanced section of the server? Yes I did. I used a PEM file. I've seen different posts about which file type it needs to be. I will redo that part with a different ssl provider but even if that was somehow incorrect, would that completely block the connection? Thanks
deecemobile 3 Posted July 16, 2019 Author Posted July 16, 2019 Yes it would. Ok I will start from scratch with the ssl cert. Thanks
Solution deecemobile 3 Posted July 17, 2019 Author Solution Posted July 17, 2019 Good news. I created a new SSL cert following this https://emby.media/community/index.php?/topic/74592-enabling-secure-connections-with-ssl/?hl=ssl. Plugged it into Emby and restarted the server. Viola. It works. Thanks community. 1
