2herbie 0 Posted July 16, 2019 Posted July 16, 2019 Hey all, Having an issue where the guide data suddenly stops downloading, and my shows stop recording because of it. If i try to manually refresh the guide data it doesn't run and it gets the following error in the logs. The only way to get it working again is by restarting the emby server. Any ideas? Have attached the full log as well. It happens every few days so if I don't notice I start losing recordings. 2019-07-16 18:15:06.681 Info HttpClient: GET http://i.mjh.nz/au/Sydney/raw-tv.m3u8 2019-07-16 18:15:06.682 Error HttpClient: Error getting response from http://i.mjh.nz/au/Sydney/raw-tv.m3u8 *** Error Report *** Version: 4.1.1.0 Command line: C:\Users\2herb\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/2herb/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: C:\Users\2herb\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\2herb\AppData\Roaming\Emby-Server\system System.ObjectDisposedException: System.ObjectDisposedException: Cannot access a disposed object. Object name: 'System.Net.Http.HttpClient'. at System.Net.Http.HttpClient.CheckDisposed() at System.Net.Http.HttpClient.SendAsync(HttpRequestMessage request, HttpCompletionOption completionOption, CancellationToken cancellationToken) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) Source: System.Net.Http TargetSite: Void CheckDisposed() 2019-07-16 18:15:06.683 Error App: Error getting channel list *** Error Report *** Version: 4.1.1.0 Command line: C:\Users\2herb\AppData\Roaming\Emby-Server\system\EmbyServer.dll -noautorunwebapp Operating system: Microsoft Windows NT 6.2.9200.0 64-Bit OS: True 64-Bit Process: True User Interactive: True Runtime: file:///C:/Users/2herb/AppData/Roaming/Emby-Server/system/System.Private.CoreLib.dll Processor count: 4 Program data path: C:\Users\2herb\AppData\Roaming\Emby-Server\programdata Application directory: C:\Users\2herb\AppData\Roaming\Emby-Server\system System.ObjectDisposedException: System.ObjectDisposedException: Cannot access a disposed object. Object name: 'System.Net.Http.HttpClient'. at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsyncInternal(HttpRequestOptions options, String httpMethod) at Emby.Server.Implementations.HttpClientManager.CoreHttpClientManager.SendAsync(HttpRequestOptions options, String httpMethod) at Emby.LiveTV.TunerHosts.M3uParser.Parse(String url, String channelIdPrefix, String tunerHostId, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.M3UTunerHost.GetChannelsInternal(TunerHostInfo info, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannels(TunerHostInfo tuner, Boolean enableCache, CancellationToken cancellationToken) at Emby.LiveTV.TunerHosts.BaseTunerHost.GetChannels(Boolean enableCache, CancellationToken cancellationToken) Source: System.Net.Http TargetSite: Void CheckDisposed() 2019-07-16 18:15:06.684 Info App: Refreshing guide with 7 days of guide data
Luke 42237 Posted July 16, 2019 Posted July 16, 2019 Hi there, that is an m3u8 url. Are you sure that is a valid m3u tuner url?
