rogerlipscombe 1 Posted September 23, 2019 Author Posted September 23, 2019 Installing 4.2 seems to have fixed it. Thanks. Nope. Not fixed. Currently using 180% CPU. Two threads both repeatedly doing the following: stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E02 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=471823660, ...}) = 0
groenator 13 Posted September 23, 2019 Posted September 23, 2019 I think it depends on what type of hardware the user has. For me, from first day the CPU usage is the same, over 100% when the TV guide is refreshed. Emby is not that smart with multithread. I am using an intel I7 8 Core CPU and emby only uses one core. Shame!
rogerlipscombe 1 Posted September 24, 2019 Author Posted September 24, 2019 (edited) I think it depends on what type of hardware the user has. For me, from first day the CPU usage is the same, over 100% when the TV guide is refreshed. Emby is not that smart with multithread. I am using an intel I7 8 Core CPU and emby only uses one core. Shame! But my bug's got nothing to do with the TV guide refresh. It's got everything to do with trying to find a suitable filename when making a recording. We can see that from the stack traces that I captured. ...which is why I suggested that you raise a different thread (and I apologise for being brusque). You've got a different bug. The fact that it manifests as 100% CPU usage is a symptom, but the cause is almost certainly different. Unfortunately, I can't find a way to update the thread title to be more specific. FWIW, my hardware is an Intel Baby Canyon NUC7I5BNH Core I5-7260U (which is why cooling's a problem). Edited September 24, 2019 by rogerlipscombe
Luke 42246 Posted September 24, 2019 Posted September 24, 2019 Regarding your findings with EnsureFileIsUnique, it should be resolved for the next release. Thanks. 1
rogerlipscombe 1 Posted October 1, 2019 Author Posted October 1, 2019 Regarding your findings with EnsureFileIsUnique, it should be resolved for the next release. Thanks. Thanks. I've upgraded to 4.2.1.0. I assume "next release" is newer than that, though...? Also, in case the data point is useful (for "yeah, that was the bug"), this seems to kick off during the day; looking in "dmesg -T", I've see the last 4 "temperature above threshold" incidents start at 16:10, 16:21, 17:30 and 12:30. I'm not sure if that's UTC or local (BST). That implies to me that it's not (?) a scheduled event. Certainly not a nightly one, anyway.
rogerlipscombe 1 Posted December 1, 2019 Author Posted December 1, 2019 (edited) I'm on 4.3.0.30 and CPU usage is improved (thrashing at ~60%, rather than 100%), but the underlying problem still exists. 'strace' on the relevant process shows: sched_yield() = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=445741352, ...}) = 0 futex(0x7fc9fc009050, FUTEX_WAIT_PRIVATE, 0, NULL) = 0 futex(0x7fc9fc009000, FUTEX_WAKE_PRIVATE, 1) = 0 sched_yield() = 0 ...and it just loops, doing this again and again and again. Note that the named file was written in June. One thing that _might_ be important: the server ran out of disk space. I wonder if it would be possible to detect this (or just the fact that it's not been successfully recording anything for a while) and display a notification on the web UI or (preferably) somewhere prominent in the client app. Edited December 1, 2019 by rogerlipscombe
Luke 42246 Posted December 1, 2019 Posted December 1, 2019 Hi, yes we do plan to detect this and recycle partial segments throughout the transcoding process in an attempt to avoid this from happening.
rogerlipscombe 1 Posted December 2, 2019 Author Posted December 2, 2019 FWIW, I've installed monit and configured it to watch for disk space and excessive CPU usage.
rogerlipscombe 1 Posted January 3, 2020 Author Posted January 3, 2020 (edited) Any progress on this? Do you need more information from me? It's still happening a couple of times a week. In fact, it literally happened immediately after I posted this. Just more of the same: stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E07 Mr.ts", {st_mode=S_IFREG|0644, st_size=444175860, ...}) = 0 stat("/mounts/data/emby/livetv/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E07 Mr.ts", ^C{st_mode=S_IFREG|0644, st_size=444175860, ...}) = 0 ... Stack: OS Thread Id: 0x36be (13) TEB information is not available so a stack size of 0xFFFF is assumed Current frame: libc.so.6!_xstat + 0x15 [/build/glibc-OTsEL5/glibc-2.27/io/../sysdeps/unix/sysv/linux/wordsize-64/xstat.c:35] Child-SP RetAddr Caller, Callee 00007F397627AC30 00007f3988c426d0 System.Native.so!SystemNative_Stat2 + 0x40, calling System.Native.so!__xstat64 00007F397627ACF0 00007f3914a8a35a (MethodDesc 00007f39151e9340 + 0x11a DomainBoundILStubClass.IL_STUB_PInvoke(System.String, FileStatus ByRef)) 00007F397627AD30 00007f3914a8a35a (MethodDesc 00007f39151e9340 + 0x11a DomainBoundILStubClass.IL_STUB_PInvoke(System.String, FileStatus ByRef)) 00007F397627ADB0 00007f39152b378d (MethodDesc 00007f39151e83d8 + 0x2d System.IO.FileSystem.FileExists(System.String, Int32, ErrorInfo ByRef)), calling 00007f3914a89888 (stub for Interop+Sys.Stat(System.String, FileStatus ByRef)) 00007F397627ADF0 00007f39152b18be (MethodDesc 00007f39151e8228 + 0x4e System.IO.PathInternal.TrimEndingDirectorySeparator(System.String)), calling (MethodDesc 00007f39151e81f8 + 0 System.IO.PathInternal.EndsInDirectorySeparator(System.ReadOnlySpan`1<Char>)) 00007F397627AE50 00007f39152aa2a6 (MethodDesc 00007f39151e78c0 + 0x66 System.IO.File.Exists(System.String)), calling (MethodDesc 00007f39151e83d8 + 0 System.IO.FileSystem.FileExists(System.String, Int32, ErrorInfo ByRef)) 00007F397627AE70 00007f3917b4ec83 (MethodDesc 00007f3917089790 + 0x63 Emby.LiveTV.EmbyTV.FileExists(System.String, System.String)) 00007F397627AEA0 00007f3917b4ebea (MethodDesc 00007f3917089780 + 0xea Emby.LiveTV.EmbyTV.EnsureFileUnique(System.String, System.String)), calling (MethodDesc 00007f3917089790 + 0 Emby.LiveTV.EmbyTV.FileExists(System.String, System.String)) 00007F397627AF00 00007f3917977e37 (MethodDesc 00007f3917181ea0 + 0x9b7 Emby.LiveTV.EmbyTV+<RecordStream>d__102.MoveNext()), calling 00007f3916b9f4d0 (stub for Emby.LiveTV.EmbyTV.EnsureFileUnique(System.String, System.String)) 00007F397627B160 00007f39144a47fd (MethodDesc 00007f3914038138 + 0x8d System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)) I've got monit to restart the emby process whenever it does, but that's not ideal -- e.g. if it happened in the middle of a scheduled recording. Edited January 3, 2020 by rogerlipscombe
rogerlipscombe 1 Posted January 3, 2020 Author Posted January 3, 2020 Ah. Just noticed the 4.3.1.0 upgrade; the changelist has at least one library scanning fix in it. Have applied the upgrade. Will watch to see if this happens again. Thanks.
ArnoRoggo 1 Posted March 12, 2020 Posted March 12, 2020 Ich hatte die Auslastung von 99 % eine Woche lang. Als ich die Erzeugung von Vorschaubildern (Bibliothek - Bearbeiten) deaktivierte, normalisierte sich die CPU-Auslastung. I had a 99% load for a week. When I deactivated the generation of thumbnails scenes (Library - Edit), the CPU utilization normalized.
Luke 42246 Posted March 12, 2020 Posted March 12, 2020 Yes thumbnail generation is a cpu intensive task. You are warned about this when you enable it. Thanks.
rogerlipscombe 1 Posted July 6, 2020 Author Posted July 6, 2020 (edited) On 1/3/2020 at 7:30 PM, Luke said: Let us know how you get on. Thanks. Running 4.4.3.0; still using an entire core. CPU temp currently 96C. Restarting emby does _not_ fix it. Still stuck in a loop stat'ing the same file over and over again. Edit: Aha. It's looping with stat("/mounts/data/emby/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E01 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=467150760, ...}) = 0 ...and it's currently attempting to record (finished about 2 minutes ago, as I type this): Brooklyn Nine-Nine - Season 4 - 1. Coral Palms Pt.1 I already have the following related files: 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.1.nfo' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.1.ts' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.ts' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt. 2.nfo' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt. 2.ts' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt.ts' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.3.nfo' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.3.ts' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts' I've got "record duplicates" (or whatever it's called) turned on for this series. Random thought: is it getting confused by the dots in the episode name? I also see the following: Brooklyn Nine-Nine S04E07 Mr.nfo Brooklyn Nine-Nine S04E07 Mr. Santiago.nfo Brooklyn Nine-Nine S04E07 Mr. Santiago.ts Brooklyn Nine-Nine S04E07 Mr.ts ...which are all presumably supposed to be the same episode. Edited July 6, 2020 by rogerlipscombe
Luke 42246 Posted July 6, 2020 Posted July 6, 2020 11 hours ago, rogerlipscombe said: Running 4.4.3.0; still using an entire core. CPU temp currently 96C. Restarting emby does _not_ fix it. Still stuck in a loop stat'ing the same file over and over again. Edit: Aha. It's looping with stat("/mounts/data/emby/recordings/Brooklyn Nine-Nine (2013)/Season 4/Brooklyn Nine-Nine S04E01 Coral Palms Pt.ts", {st_mode=S_IFREG|0644, st_size=467150760, ...}) = 0 ...and it's currently attempting to record (finished about 2 minutes ago, as I type this): Brooklyn Nine-Nine - Season 4 - 1. Coral Palms Pt.1 I already have the following related files: 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.1.nfo' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.1.ts' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E01 Coral Palms Pt.ts' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt. 2.nfo' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt. 2.ts' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E02 Coral Palms Pt.ts' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.3.nfo' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.3.ts' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.nfo' 'Brooklyn Nine-Nine S04E03 Coral Palms Pt.ts' I've got "record duplicates" (or whatever it's called) turned on for this series. Random thought: is it getting confused by the dots in the episode name? I also see the following: Brooklyn Nine-Nine S04E07 Mr.nfo Brooklyn Nine-Nine S04E07 Mr. Santiago.nfo Brooklyn Nine-Nine S04E07 Mr. Santiago.ts Brooklyn Nine-Nine S04E07 Mr.ts ...which are all presumably supposed to be the same episode. Can you please attach the emby server log from when this happened? Thanks.
rogerlipscombe 1 Posted July 27, 2020 Author Posted July 27, 2020 Sorry, was on vacation. Will capture a log and strace next time it happens.
rogerlipscombe 1 Posted August 5, 2020 Author Posted August 5, 2020 This hasn't happened recently. I'm going to assume that it's because I turned off Record Duplicates for this particular series (or maybe they stopped showing repeats of Brooklyn Nine-Nine). I've got monit monitoring it, so if it happens again, I'll know.
