AdrianW 1058 Posted May 28, 2015 Posted May 28, 2015 (edited) Just check the number of matching results for a search on this badly worded section of "his" post: Not a Blu-ray ripper is able to crack all the Blu-ray Discs as decryption Edited May 28, 2015 by AdrianW 1
Robert Arellano 0 Posted May 29, 2015 Posted May 29, 2015 I use Pavtube Bytecopy, since it not only allows to output lossless MKV format with my subtitle tracks and audio streams well preserved, it also has a "Profile Settings" window, so that I can flexibly adjust the output video file size and codec by my own preference. What's more, I can directly output to my portable device optimized format, then I do not have to consider other incompatible problems.
emma24xia 0 Posted May 29, 2015 Posted May 29, 2015 Among all four too packages, I prefer ByteCopy. Using ByteCopy, I can easily rip and convert BD/DVD content with few clicks as well as customize its settings for getting needed results. It can backup my Blu-rays to MKV with all audio and subtitle tracks within simple steps. In short, it is the all-in-one solution for ripping DVDs onto the hard disk easily.
AdrianW 1058 Posted May 29, 2015 Posted May 29, 2015 I think someone should lock this thread - we've now got three bots posting to it.
