xnappo 1611 Posted May 26, 2014 Posted May 26, 2014 Work is underway to provide a mechanism to set default views as often requested. This requires both a skin and addon update. The Aeon Nox and XBMB3C Gits have this ready to try. Setting is accessed from the AddOn root menu. xnappo 1
tube82 73 Posted May 27, 2014 Posted May 27, 2014 Awesome addition! One of the few things that still is/was very clumsy to set up!
xnappo 1611 Posted May 31, 2014 Author Posted May 31, 2014 I added more view types. I am marking this complete but please test more. @@im85288 @@elcabong - please add views.xml to your skins if you haven't already. xnappo 1
im85288 1493 Posted June 3, 2014 Posted June 3, 2014 Just got round to testing this and have to say Awesome addition Works perfectly and easy to integrate. I have now added support to both Eminence and AeonMQ5 and updated the repo with a new version of the XBMB3C add-on. 2
xnappo 1611 Posted June 3, 2014 Author Posted June 3, 2014 Just got round to testing this and have to say Awesome addition Works perfectly and easy to integrate. I have now added support to both Eminence and AeonMQ5 and updated the repo with a new version of the XBMB3C add-on. Excellent! Thanks. xnappo
saitoh183 137 Posted June 13, 2014 Posted June 13, 2014 Just got round to testing this and have to say Awesome addition Works perfectly and easy to integrate. I have now added support to both Eminence and AeonMQ5 and updated the repo with a new version of the XBMB3C add-on. will you add it to Xperience 1080++?
xnappo 1611 Posted June 13, 2014 Author Posted June 13, 2014 (edited) @@saitoh183 - You can help. Make a file in 'skin.xperience1080plusplus' called 'views.xml' containing this: <views> <view id="View50" value="50" /> <view id="View53" value="53" /> <view id="View56" value="56" /> <view id="View57" value="57" /> <view id="View502" value="502" /> <view id="View503" value="503" /> <view id="View504" value="504" /> <view id="View505" value="505" /> <view id="View506" value="506" /> <view id="View507" value="507" /> <view id="View508" value="508" /> <view id="View509" value="509" /> <view id="View510" value="510" /> <view id="View511" value="511" /> <view id="View513" value="513" /> <view id="View60" value="60" /> <view id="View600" value="600" /> <view id="View552" value="552" /> <view id="View652" value="652" /> <view id="View566" value="566" /> <view id="View577" value="577" /> <view id="View582" value="582" /> </views> Go through and set each one, and change the "ViewXXX" to the correct name. This is the tedious bit - but it would be appreciated. Some of the views may not work because they are only for special cases. xnappo Edited June 13, 2014 by xnappo
saitoh183 137 Posted June 13, 2014 Posted June 13, 2014 @@saitoh183 - You can help. Make a file in 'skin.xperience1080plusplus' called 'views.xml' containing this: <views> <view id="View50" value="50" /> <view id="View53" value="53" /> <view id="View56" value="56" /> <view id="View57" value="57" /> <view id="View502" value="502" /> <view id="View503" value="503" /> <view id="View504" value="504" /> <view id="View505" value="505" /> <view id="View506" value="506" /> <view id="View507" value="507" /> <view id="View508" value="508" /> <view id="View509" value="509" /> <view id="View510" value="510" /> <view id="View511" value="511" /> <view id="View513" value="513" /> <view id="View60" value="60" /> <view id="View600" value="600" /> <view id="View552" value="552" /> <view id="View652" value="652" /> <view id="View566" value="566" /> <view id="View577" value="577" /> <view id="View582" value="582" /> </views> Go through and set each one, and change the "ViewXXX" to the correct name. This is the tedious bit - but it would be appreciated. Some of the views may not work because they are only for special cases. xnappo Cool will look into this when i get home
saitoh183 137 Posted June 16, 2014 Posted June 16, 2014 @@saitoh183 - any progress? xnappo Nah haven had a chance to have a look yet...all i have to say to that is...baby and no sleep
saitoh183 137 Posted June 16, 2014 Posted June 16, 2014 (edited) I just had a look in 1080++ folder and the file already exist <views> <view id="List" value="50" /> <view id="BannerPlex" value="53" /> <view id="LoveFilm" value="566" /> <view id="WallVideo" value="502" /> <view id="PosterInfo" value="56" /> <view id="LowInfoList" value="57" /> <view id="VideoWall" value="582" /> <view id="PanelCarousel" value="503" /> <view id="BannerCarousel" value="504" /> <view id="ClassicPoster" value="506" /> <view id="Landscape" value="507" /> <view id="PanelVideo" value="508" /> <view id="BannerPanelVideo" value="509" /> <view id="PanelWall" value="510" /> <view id="LowList" value="511" /> <view id="LandscapeCarousel" value="513" /> <view id="Banner" value="60" /> <view id="BannerOriginal" value="600" /> <view id="InfoList" value="552" /> <view id="Top250InfoList" value="652" /> </views> Just to know what this does. Does this fix the issue of having to set a view to each show on the season level. Like if i want Banner view for TV and at season level i want Low list, will i be able to set this globally for all shows at once? Edited June 16, 2014 by saitoh183
saitoh183 137 Posted June 16, 2014 Posted June 16, 2014 Hah, @@im85288 beat you to it. xnappo indeed...and what about my other question
xnappo 1611 Posted June 16, 2014 Author Posted June 16, 2014 Yes - that is what it does. Go into the main addon directory list and you will find a 'Set Views' directory. xnappo
saitoh183 137 Posted June 16, 2014 Posted June 16, 2014 Yes - that is what it does. Go into the main addon directory list and you will find a 'Set Views' directory. xnappo Can you give an example...cuz im not finding it
im85288 1493 Posted June 16, 2014 Posted June 16, 2014 (edited) You need to scroll down to nearly the very bottom where there is an option to set the views (below Search and above Edit Background Image List) Edited June 16, 2014 by im85288 1
saitoh183 137 Posted June 16, 2014 Posted June 16, 2014 Perfect! Thanks a lot. I've tried it and it seems to be working really well. Keep it up guys. 1
tired dad 28 Posted January 21, 2015 Posted January 21, 2015 You need to scroll down to nearly the very bottom where there is an option to set the views (below Search and above Edit Background Image List) Hi, Sorry for the noob question.. but I cannot locate this in the Ttian skin.... do we look for this from "add-on browser", or is there another "add-on" somewhere? Do I have to be in the "videos" section, or somewhere else? Thanks!
im85288 1493 Posted January 21, 2015 Posted January 21, 2015 Hi, Sorry for the noob question.. but I cannot locate this in the Ttian skin.... do we look for this from "add-on browser", or is there another "add-on" somewhere? Do I have to be in the "videos" section, or somewhere else? Thanks! Hi, this is an old feature and not needed if your using either Titan or 1080XF. The views are set automagically now, so that it mimics the native Kodi library experience
pünktchen 1410 Posted January 21, 2015 Posted January 21, 2015 But it is also available in Titan and really nice if you want different views for different collections with the same media type. You have to go to Videos or Music -> Addons -> Mediabrowser -> bottom of the list!
tired dad 28 Posted January 21, 2015 Posted January 21, 2015 Hi, this is an old feature and not needed if your using either Titan or 1080XF. The views are set automagically now, so that it mimics the native Kodi library experience Thanks for letting me know. So, if I change one folder to be all "large poster", it will do this for all other folders? (I have fodlers for kids movies, tv shows, classics, foreign, et cetera) Once ... don't ask me how... I did get to see the screen noted above, but for the life of me, I have no idea how I got there and never was able to find my way back.
Angelblue05 4132 Posted May 17, 2015 Posted May 17, 2015 @@Harvinder no idea why you'd post to an old thread. Anyway, here's all the info you need to know: http://emby.media/community/index.php?/topic/19739-introducing-emby-for-kodi-open-beta/ Some of the information is outdated, but it should be straight forward. 1
