Pilothobs 0 Posted July 12, 2019 Posted July 12, 2019 Hello everyone I am a long time Plex user for my backend and Kodi for the front. I have messed around with emby but never got very far. I am looking at replacing my server and using emby. I like the emby thearter running on my Pi boxes. The problem I am having is that I cant get my Live TV to work in emby. I have put in the m3u file with the _plus&output=ts there and not there. I have tried/checked: Live TV service - Okay Firewall - Set Portforward - Set Just killing me that I might have missed something simple Thanks in advance Hobs logs.txt
Luke 42239 Posted July 12, 2019 Posted July 12, 2019 Hi there, can you please describe the problem that you're having? thanks. 1
Pilothobs 0 Posted July 12, 2019 Author Posted July 12, 2019 Hello I have no guide or channels Sent from my SM-N960U1 using Tapatalk
Pilothobs 0 Posted July 12, 2019 Author Posted July 12, 2019 I think the problem is my premier membership Sent from my SM-N960U1 using Tapatalk
ebr 16332 Posted July 13, 2019 Posted July 13, 2019 I think the problem is my premier membership Sent from my SM-N960U1 using Tapatalk Hi. Exactly what do you mean by that?
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 Hey Guys. I cant seem to get Nextpvr to work with emby. I am not sure where to go next. thanks for your help here are some shots that might help.... Logs too In this shot nextpvr is open on top of emby. settings too. You can see that nextpver is working Here are the logs... skira….pdf
emveepee 133 Posted July 13, 2019 Posted July 13, 2019 That is definitely v4 of NextPVR, it is responding to the old JSON. Did you run the scheduled task import the guide data? Martin
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 According to the server log, next pvr is refusing connection attempts from emby server, so you probably need to configure next pvr to allow that.
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 WOW Thanks for the quick replies. Do I switch to V5? Its running on a Windows 10 machine How do I configure nextpvr to allow connections to emby?
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 I went to a networked computer and tried to access nextpvr. It loaded but wouldn't get the guide or play channels. I then went back to the windows machine and saw this I think I should unintall V4 and install V5 Thoughts?
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 The next pvr plugin in the catalog is for v4. I'm not sure it will function with v5 at this time.
emveepee 133 Posted July 13, 2019 Posted July 13, 2019 According to the server log, next pvr is refusing connection attempts from emby server, so you probably need to configure next pvr to allow that. I see the connection is ok 2019-07-13 10:22:31.152 Info App: [NextPvr] Session initiated The requests that are failing are art requests which is why I suggest syncing the guide. Martin
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 (edited) OK I restarted the windows machine and it seems to be working only for a minute then it went and stopped again Edited July 13, 2019 by Pilothobs
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 Can you please attach the log file in its original plain text format? Thanks.
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 (edited) Can you please attach the log file in its original plain text format? Thanks. Log.txt Edited July 13, 2019 by Pilothobs
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 Ok, please try running the refresh guide scheduled task in emby server. thanks.
emveepee 133 Posted July 13, 2019 Posted July 13, 2019 Looking at the number of episode art requests from Emby, and from the screen shot you look to be using IPTV with a lot of channel I do not think that is a great combination with v4. I would consider upgrading to v5 and for the best metadata experience mapping as many channel to Schedules Direct guide data as possible. If your XMLTV guide data has poster URL's that might be something that sub can use to improve things to, not sure if he handles that. Martin
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 Ok, please try running the refresh guide scheduled task in emby server. thanks. Done…. Looking at the number of episode art requests from Emby, and from the screen shot you look to be using IPTV with a lot of channel I do not think that is a great combination with v4. I would consider upgrading to v5 and for the best metadata experience mapping as many channel to Schedules Direct guide data as possible. If your XMLTV guide data has poster URL's that might be something that sub can use to improve things to, not sure if he handles that. Martin Martin I think you are onto something here. The IPTV provider has 15K+ channels and art for each.
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 Emby supports m3u tuners directly. Are you sure you even need to be using next pvr? You can setup an m3u tuner directly in the live tv section of the server dashboard. thanks.
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 Looking at the number of episode art requests from Emby, and from the screen shot you look to be using IPTV with a lot of channel I do not think that is a great combination with v4. I would consider upgrading to v5 and for the best metadata experience mapping as many channel to Schedules Direct guide data as possible. If your XMLTV guide data has poster URL's that might be something that sub can use to improve things to, not sure if he handles that. Martin Admin says V5 won’t work with the nextpvr plugin
emveepee 133 Posted July 13, 2019 Posted July 13, 2019 I wrote the v5 update it is working fine just not submitted to the catalog yet. I am waiting for NextPVR release candidate. If you have 15k channels I wouldn't use Emby 4.1.1 the guide refresh would be too slow consider their beta. If you are happy with how Emby handles m3u IPTV I am not sure why NextPVR would be needed. Martin
Pilothobs 0 Posted July 13, 2019 Author Posted July 13, 2019 Emby supports m3u tuners directly. Are you sure you even need to be using next pvr? You can setup an m3u tuner directly in the live tv section of the server dashboard. thanks. I tried that too. Got the channels to load but won't play Im going to try a different IPTV provider
Luke 42239 Posted July 13, 2019 Posted July 13, 2019 I tried that too. Got the channels to load but won't play Im going to try a different IPTV provider Can we please look at a log example of that? thanks.
