Prydwyn 6 Posted July 12, 2019 Posted July 12, 2019 I'm starting a new topic, as no one seems to be looking at the old one. Currently using 3.0.60 The issue has been present since .51 Audio is ahead of the video when using Emby native player, using device speakers or wired speakers/headphones Audio is OK using VLC as an external player, and OK on bluetooth using the Emby player. Using VLC as a permanent solution wouldn't be a problem (for me), except that there is no "Resume" option in Emby - it just assumes that you are going to play from the beginning, and if you are watching something in segments, it is a real PITAS to remember to make a note of exactly what time duration you got to! Using LG Q6 Mobile Phone Android 8.1 (3GB/32GB) Octacore Armv7 rev processor, and Alldocube M5X Tablet Mediatek x27 Decacore Android 8.0 (4GB/64GB). Issue is identical on both devices.
neik 874 Posted July 12, 2019 Posted July 12, 2019 Seeing the same, doesn't matter what is played (movie or live tv) audio is totally out of sync. @@Luke, @@ebr, can we please have a feedback on this? Thanks!
daedalus 434 Posted July 13, 2019 Posted July 13, 2019 https://emby.media/community/index.php?/topic/61915-audio-sync-issues-with-3010/
F1nchy 29 Posted July 17, 2019 Posted July 17, 2019 Hi guysI'm finding the Android Emby app on my Samsung Galaxy S3 Tab it always out of sync. I don't think there's anything wrong with the video as it's fine on my Android TV and also my Shield TV. Is there an issue with the Android audio sync at the moment?
Prydwyn 6 Posted July 17, 2019 Author Posted July 17, 2019 This has been an issue for ages. There are other posts on this. See threads https://emby.media/community/index.php?/topic/61915-audio-sync-issues-with-3010/ (which obviously isn't answered, even though it is marked), and this one https://emby.media/community/index.php?/topic/75368-audio-sync-issues/
Prydwyn 6 Posted July 17, 2019 Author Posted July 17, 2019 Just downloaded 3.0.62 - No change (see my first post as to symptoms).
F1nchy 29 Posted July 18, 2019 Posted July 18, 2019 Ah, thanks, at least it's not just me. Hopefully they can get it resolved soon
Luke 42245 Posted August 21, 2019 Posted August 21, 2019 If you can try the beta channel that would be helpful as there are changes related to this. Thanks.
zyfinity 15 Posted August 23, 2019 Posted August 23, 2019 Just want to say that switching to the beta app for android on google play solved the audio sync issue!
Prydwyn 6 Posted August 23, 2019 Author Posted August 23, 2019 3.0.73 - Sync still good. Looks like you might have cracked it
