jakrigg 4 Posted July 10, 2019 Posted July 10, 2019 Version 4.2.0.26-beta Hi there, currently having an issue with playing Live TV m3u sources. Having either: -"no compatible streams" -"spinning wheel" -"eventualy play 'some' streams after massive delay Opening the M3U streams via VLC works flawless. So far I have:- -removed and re-added source m3u and xml -restarted server -updated to latest beta -confirmed there are no outgoing dns resolution issues from the server Attached is the server log from a restart - failing to play a couple. If there are any clues there, please let me know. embyserver.txt Kind regards, Jonny
Luke 42246 Posted July 10, 2019 Posted July 10, 2019 Hi, have you entered your Emby Premiere key into your server dashboard?
Luke 42246 Posted July 10, 2019 Posted July 10, 2019 Can you please attach the complete emby server log? thanks. 1
jakrigg 4 Posted July 10, 2019 Author Posted July 10, 2019 Hi Luke, attached 2 most recent. Hope it helps, Cheers, Jonny embyserver-63698360171.txt embyserver.txt
Luke 42246 Posted July 10, 2019 Posted July 10, 2019 Ok, i'm going to have to add logging, so please try the next beta build and then let's compare. thanks.
jakrigg 4 Posted July 15, 2019 Author Posted July 15, 2019 Hi Luke, I have done some more testing. On beta 28, still the same. - some live tv streams work fine - some do not - just sit there. In the attached server log, i finished on a live radio stream which would not play embyserver4.2.0.28.txt I then downgraded to 4.1.1.0 and ran the same tests - i experienced no issues and the streams on all (including the live radio stream) performed as expected embyserver4.1.1.0.txt Hope the attached can provide some info Cheers, Jonny
jakrigg 4 Posted July 15, 2019 Author Posted July 15, 2019 I did try this also, however here is the log with this step. Steps:- -reboot -refresh guide (twice) -play 7mate stream (success) -play radio stream (fail - error report in log) just spinning wheel on ui, no error Note on 4.1.1.0 or using vlc the radio stream works fine embyserver.txt
Luke 42246 Posted July 15, 2019 Posted July 15, 2019 @@jakrigg, try removing all tuners and guide sources from emby server, then run the guide refresh to clear out the database, then add them back. thanks.
jakrigg 4 Posted July 16, 2019 Author Posted July 16, 2019 (edited) Hi Luke, done - also same result. Log attached embyserver.txt Cheers, Jonny Edited July 16, 2019 by jakrigg
Luke 42246 Posted July 16, 2019 Posted July 16, 2019 Your provider is sending back a response header saying this stream requires winamp. I have no idea what that means, sorry. You'll have to ask them. Maybe you can play with customizing the m3u tuner settings to make emby server appear like it is winamp.
jakrigg 4 Posted July 16, 2019 Author Posted July 16, 2019 Do you know why this works fine on emby 4.1.1.0 and not on these beta versions?
Luke 42246 Posted July 16, 2019 Posted July 16, 2019 Unfortunately I can't make a direct comparison because your 4.1.1 log shows an m3u8 url whereas your 4.2 logs are different. It's two different inputs that get handled differently. My guess is if you tried the exact same thing on 4.2 it would still work.
jakrigg 4 Posted July 16, 2019 Author Posted July 16, 2019 I can re-do the test when I get home and I'll upload the logs. I am only ever using the same raw playlist and XML provider so not sure why you are seeing a difference
Luke 42246 Posted July 16, 2019 Posted July 16, 2019 Make sure you're testing with the exact same channel. thanks.
jakrigg 4 Posted July 16, 2019 Author Posted July 16, 2019 Hi Luke, no worries - done. Steps:- -delete m3u and xml sources -downgrade to 4.1.1.0 -reboot -refresh guide data (sources empty) -add sources back in -let auto refresh happen & also manual refresh guide data -tested playing triplej station - successful straight away. embyserver-4.1.1.0.txt Next: -delete m3u and xml sources -upgrade to 4.2.0.30 -reboot -add sources back in -let auto refresh happen & also manual refresh guide data -tested playing triplej station - fails - just spinning wheel embyserver-4.2.0.30.txt Cheers, Jonny
Luke 42246 Posted July 16, 2019 Posted July 16, 2019 Ok thanks. @@softworkz will be looking at this. 1
Solution softworkz 5133 Posted July 21, 2019 Solution Posted July 21, 2019 @@jakrigg - thanks for supplying the stream details. After adding the m3u tuner there were the following channels added: triplej triplej triplej unearthed All three channels played fine. Could you please retry with the latest beta? 1
jakrigg 4 Posted July 21, 2019 Author Posted July 21, 2019 Hi mate, yes now working again with beta 33 not with previous 4.2.0.x betas Was the issue to do with how ffmpeg was handling the streams? Thanks for your help, jonny
Luke 42246 Posted July 21, 2019 Posted July 21, 2019 We did not do anything specifically for this, so i guess we'll have to keep an eye on it. Could be a result of changes in the remote stream.
