thalex 0 Posted July 9, 2019 Posted July 9, 2019 Hi, I'm running the latest Emby build on a Synology 918+. Transcoding is set to Advance I'm super happy with the streaming performance overall but have one question. Downloading/Converting a file to my mobile device utilizes max 10% of the CPU (ffmpeg task). and it takes quite long. Is it possible to allocate more CPU power to that task to increase the converting speed? Thx
Solution Luke 42242 Posted July 9, 2019 Solution Posted July 9, 2019 Hi there, yes, go into your server download & sync settings, and enable full speed conversion. Please let us know if this helps. Thanks. 1
