Shidapu
Heya. Will be posting log.
The issue 1:
AutoOrganize is setup to build Season folders as: Season-0, Season-1 etc.
But even though it's setup like this, i still get Season 0, Season 1 folders.
It seems to only affect the last season of many shows.
See log1.
Why am i doing it this way instead of the default way?
If i don't do it this way, new episodes won't show in library, so a temporary solution has been to rename every season folder.
The issue 2:
There seem to be thumbnails failing.
See log2.
Please see logs.
log.txt
log2.txt
Edited by Shidapu
Hi, what do you mean thumbnails failing?
Shidapu
Log2.txt is from the thumbnailsfailed log in programdata folder.
I just rebooted the server, and thumbnails no longer fail it seems. No log -> Should be good. :P
Edited by Shidapu
Thanks for the feedback.
