Seven_ 0 Posted July 7, 2019 Posted July 7, 2019 Hi, I thought to give another try to Emby after 1 year Question: is possible to arrange Home screen ? meaning Latest TV Show Up (want to put it above Latest Movies, see picture Question: why after 1 year of absence when navigating to right and down will go as far as he can, still no fix, i posted this issue before
Luke 42186 Posted July 7, 2019 Posted July 7, 2019 Hi there, yes it is possible. Have you explored the home screen settings for your emby user?
Seven_ 0 Posted July 7, 2019 Author Posted July 7, 2019 Hi there, yes it is possible. Have you explored the home screen settings for your emby user? yes i did I think you refer at the settings from Home Screen > Home Screen Section 1 to 7, option Latest Media show for both on same order, there is nothing to show or rearrange, what i want is to keep the library order as is and only Latest TV show to move above Latest Movies
Luke 42186 Posted July 7, 2019 Posted July 7, 2019 Ok you'd have to change the library order for that to happen. The latest section just goes by that. It's possible to expand this for more control in the future.
dirtylilfunker 4 Posted April 17, 2022 Posted April 17, 2022 Hi, Was this ever sorted? My users libraries are all in alphabetical order as opposed to a custom order. There's no way for each user to amend their library order in their own settings. How is this possible? Thanks
GrimReaper 4854 Posted April 17, 2022 Posted April 17, 2022 2 minutes ago, dirtylilfunker said: There's no way for each user to amend their library order in their own settings. What do you mean by that? Each user can arrange library order as preferred and irrespective to other users and/or default order.
dirtylilfunker 4 Posted April 17, 2022 Posted April 17, 2022 Never mind I've just found it. I was at my friends house last night and there's no way for her to re-arrange the library order in her settings but just found it in admin by clicking on the 'edit this users profile' etc. where you can move the library up and down. Knew i'd seen this before. Cheers
Luke 42186 Posted April 17, 2022 Posted April 17, 2022 6 hours ago, dirtylilfunker said: Never mind I've just found it. I was at my friends house last night and there's no way for her to re-arrange the library order in her settings but just found it in admin by clicking on the 'edit this users profile' etc. where you can move the library up and down. Knew i'd seen this before. Cheers Hi, if she clicks her user icon in the top right then the can change home screen options from there.
dirtylilfunker 4 Posted April 19, 2022 Posted April 19, 2022 Thanks, we did try this and there was no way for a user, through the app, to change the order the library appears on the homepage; only what they can see on the homepage. Unless I've missed something? Cheers
GrimReaper 4854 Posted April 19, 2022 Posted April 19, 2022 7 minutes ago, dirtylilfunker said: through the app Which client app?
kevinw 8 Posted May 19, 2022 Posted May 19, 2022 (edited) Looks like dirtylilfunker didn't come back with an answer so maybe I can jump in as I've been looking for an answer to the same issue. In my case it's the Firestick app. The Home Screen Layout setting only allows me to change the order of the sections and the libraries that will appear in latest and next up. I can see no way to change the library order. Edit was to fix typo. Kevin Edited May 19, 2022 by kevinw
GrimReaper 4854 Posted May 19, 2022 Posted May 19, 2022 5 minutes ago, kevinw said: Looks like dirtylilfunker didn't come back with an answer so maybe I can jump in as I've been looking for an answer to the same issue. In my case it's the Firestick app. The Home Screen Layout setting only allows me to change the order of the sections and the libraries that will appear in latest and next up. I can see no way to change the library order. Edit was to fix typo. Kevin Whichever library order you want, set it in Web app UI and Firestick app will pick it up. 1
Happy2Play 9800 Posted May 19, 2022 Posted May 19, 2022 4 minutes ago, kevinw said: Looks like dirtylilfunker didn't come back with an answer so maybe I can jump in as I've been looking for an answer to the same issue. In my case it's the Firestick app. The Home Screen Layout setting only allows me to change the order of the sections and the libraries that will appear in latest and next up. I can see no way to change the library order. Edit was to fix typo. Kevin Some settings are only editable via the web client. I don't use a Firestick but assume it honor the user setting applied for this order like other apps. 1
kevinw 8 Posted May 19, 2022 Posted May 19, 2022 (edited) 11 minutes ago, GrimReaper said: Whichever library order you want, set it in Web app UI and Firestick app will pick it up. That was quick and that did it. Thank you. I must have done that previously as my main user has the libraries in a logical order but I was setting up a new user and it's a Very Long Time since I've done that and had forgotten how. Thanks again and thanks to Happy2Play as well. Kevin. Edited May 19, 2022 by kevinw 1 1
