chef 3811 Posted July 7, 2019 Posted July 7, 2019 Nvidia Quadro K4000 I found a good deal on one, but when I look at the Nvidia web site the line that explains this card is blocked out. If this does use nvenc, will this help my server be better? Thanks to anyone who can let me know.
Guest asrequested Posted July 7, 2019 Posted July 7, 2019 That's not a simple yes or no. What are you throwing at it? Have you looked at the matrix? https://developer.nvidia.com/video-encode-decode-gpu-support-matrix 1
lorac 119 Posted July 7, 2019 Posted July 7, 2019 For H264 it might help somewhat. Consider the card was launched six years ago so i wouldn't expect that much. A P4000 would be better in most cases but it does depend what you need to transcode. Sent from my ONEPLUS A6003 using Tapatalk 1
chef 3811 Posted July 7, 2019 Author Posted July 7, 2019 (edited) P4000 are a bit pricey. Are there any gtx models that could be recommended for nvenc? I did see that matrix website but the k4000 line was blacked out. Edited July 7, 2019 by chef
Guest asrequested Posted July 7, 2019 Posted July 7, 2019 You'd be ok with a GTX 1050. And if you need more than two simultaneous transcodes, use the patch to unlock it.
Guest asrequested Posted July 7, 2019 Posted July 7, 2019 I actually have a GTX 1060 laying around that I'm going to sell.
chef 3811 Posted July 7, 2019 Author Posted July 7, 2019 Would you interested in pm'ing me the details of that card? Would a 1650 also be a good choice?
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 I did see that matrix website but the k4000 line was blacked out. What do you mean blacked out?
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 Must be a device limitation or something as I don't see those blackouts on my desktop.
lorac 119 Posted July 7, 2019 Posted July 7, 2019 Click on the Quadro button at the bottom. You won't get any H265 support with that card. You want a card built on the Pascal engine. Sent from my ONEPLUS A6003 using Tapatalk
Sammy 791 Posted August 16, 2019 Posted August 16, 2019 Click on the Quadro button at the bottom. You won't get any H265 support with that card. You want a card built on the Pascal engine. Sent from my ONEPLUS A6003 using Tapatalk What card? I need h265 support for sure going forward and even right now..
lorac 119 Posted August 17, 2019 Posted August 17, 2019 Quadro P4000. If you're interested in a lower cost option I believe there's a hack you can use on the GeForce 10 series cards to allow more than two playback streams as well.
Sammy 791 Posted August 17, 2019 Posted August 17, 2019 I went with a GTX 1660 and it works alright. I haven't yet hacked it to have more sessions. Emby will use the CPU after the two sessions are used up. Works great for me [emoji3] How much is such card? Sent from my SM-G960U1 using Tapatalk
lorac 119 Posted August 17, 2019 Posted August 17, 2019 one would assume there are multiple types. I'd check ebay. Off the top of my head i'm guessing somewhere around $150 vs. $550 or so for the P4000.
pir8radio 1313 Posted August 20, 2019 Posted August 20, 2019 just go for the Quadro RTX 4000 Im about to pick up a few, ill have some p4000's available if anyone is interested.. Not sure when that will be, gotta get the new ones and get to the datacenter to swap them out. 1
Sammy 791 Posted August 21, 2019 Posted August 21, 2019 just go for the Quadro RTX 4000 Im about to pick up a few, ill have some p4000's available if anyone is interested.. Not sure when that will be, gotta get the new ones and get to the datacenter to swap them out. Quantos? How much?
