igeoorge 26 Posted July 7, 2019 Posted July 7, 2019 Friends, how are you? At the moment it is a content search for actor / actress just highlight 12 movies or series. How can I increase this number? Example: I like a lot and many movies of the actor Liam Neeson, 12 years ago, more on my server I have more than 12. How can I make all appear?
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 Can't be done with css. Have a look at "*\system\dashboard-ui\scripts\itembynamedetailpage.js". But the header in each section already will display all items for the Actor.
igeoorge 26 Posted July 7, 2019 Author Posted July 7, 2019 Can't be done with css. Have a look at "*\system\dashboard-ui\scripts\itembynamedetailpage.js". But the header in each section already will display all items for the Actor. I mean that part. I used this actor only as an example. In search of this research, I am limited in the maximum 12 films or series
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 (edited) I mean that part. I used this actor only as an example. In search of this research, I am limited in the maximum 12 films or series That is where my image came from, header links are the easiest way to show all of that content type for the actor. But the script above is where the section limits are applied. Edited July 7, 2019 by Happy2Play
igeoorge 26 Posted July 7, 2019 Author Posted July 7, 2019 (edited) Sorry, I still do not understand. Could you explain it again, please? Edited July 7, 2019 by igeoorge
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 (edited) Sorry, I still do not understand. Could you explain it again, please? Updated post above but the Actor details page list items by type (Movie, Series, Episode) that applies to the Actor/person. Each header is a link that queries the person and shows all of that content type for the person. If you still want to modify the scroll sections then update the script above. But will have to be updated with every server update. Edited July 7, 2019 by Happy2Play
igeoorge 26 Posted July 7, 2019 Author Posted July 7, 2019 Access the informed website: mby-Server\system\dashboard-ui\scripts I looked for limit: 12 - since it is the limit of movies that appear. I found it and had a party, but unfortunately it did not work
Solution Happy2Play 9811 Posted July 7, 2019 Solution Posted July 7, 2019 Access the informed website: mby-Server\system\dashboard-ui\scripts I looked for limit: 12 - since it is the limit of movies that appear. I found it and had a party, but unfortunately it did not work I just edited it for movies to 100 and it scrolls all 64 of my Liam Neeson movies. Sometimes you have to refresh the page, clear the browser history or even restart the server as last resort. 1
Happy2Play 9811 Posted July 7, 2019 Posted July 7, 2019 Actually I will have to verify that this works on stable as I am testing on beta 4.2.0.24.
igeoorge 26 Posted July 7, 2019 Author Posted July 7, 2019 Actually I will have to verify that this works on stable as I am testing on beta 4.2.0.24. I was looking in the wrong file. I forgive. Thanks for your help.
AdrianW 1058 Posted August 1, 2019 Posted August 1, 2019 Why does the WebUI have such a small limit of 12 items? I just spent a good 30 minutes trying to figure out why a particular movie was missing from the list for an actor. Then I found this thread. At least ET doesn't appear to have a limit. 1
