blade005 185 Posted July 9, 2019 Posted July 9, 2019 (edited) Well, success!! That method seems to work just fine. All my actor pictures show and nothing else seems to be affected as far as I can tell. I did update both "Path" and "Images" in the "MediaItems" table. I did them separately just because I was lazy and didn't feel like looking up how to combine the statements to do it at once. I'm sure it's simple but this was just as quick. First I did: UPDATE MediaItems SET Path = REPLACE(Path,'\\192.168.1.12\Emby\metadata','%MetadataPath%'); Then I did: UPDATE MediaItems SET Images = REPLACE(Images,'\\192.168.1.12\Emby\metadata','%MetadataPath%'); Thanks for sharing this. Since the update to Emby Server 4.0 I have been chasing an issue with Actor Images pointing to a long ago abandoned cache path. There didn't seem to be any way to update, delete or correct these once identified. Followed your suggestion above on updating all paths back to %MetadataPath% default for the two columns in Library.db file after creating a backup. Initial results show success in Actor Images displaying as expected. For the ones that still show a blank image I can now update via EDIT IMAGES and the update is written to the default path. Edited July 9, 2019 by blade005
