Stop ffmpeg running during scan
Go to solution Solved by flakie,
Made the mistake of trying to play an  mkv during the initial scan of the system.
ffmpeg is eating all the cpu.
Rebooted nas in an attempt to stop it but it has started up again.
How do I kill it?
<edit> ii pressed pay for a whole season, accidentality. did not think nothing of it at the time. but just noticed ffmpeg running for couple of hours, even though nothing playing</edit>
<edit 2>ok logs show a different video mentioned to what i was playing. dont really understand the logs but maybe it is image extraction? if so why has ffmpeg used so little cpu up until now?</edit>
Edited by flakie
  • Solution
Never mind. Just seemed to be a few problematic files. Back to reasonable cpu use now.
