CChris 59 Posted July 5, 2019 Posted July 5, 2019 Hi, I am running several virtual Containers on my homeserver.One of them is a MySQL / Maria DB.It would be nice, if you could select which Database engine you want to use during the setup...Default could be the internal SQLite file based DB - but If I could select MySQL and provide the MySQL Host and so on.benefits:After an issue with the Emby Server and a potential reinstallation of the app, there is no need to re-write the Database.Each information could still be available since the DB is running on a dedicated machine.As far as I know, the DB does host some of the information like watched status, etc. (which could also be saved in the meta-data file...) But what else is being stored within the SQLite? What do you think? Thanks and with best regards,Christoph 1
ebr 16339 Posted July 5, 2019 Posted July 5, 2019 Actually, more discussion has taken place here: MySQL Support
