Guest Posted July 5, 2019 Posted July 5, 2019 (edited) Hi,A client reported a bug and I was able to reproduce the error and I even got the reason why the error occurs and I report it here so that it can be resolved. I have the series from Spain Vis a Vis in versions dubbed and subtitled, in separate folders (series dubbed and would be subtitled) and when giving the pause in the reproduction of the episode, (subtitled) when returning to homepage of the Emby, the system registers like " Continue watching "the two versions of the episodes, when should register only the subtitled version.The same error also occurs with movies that I have in both versions. Edited July 5, 2019 by CarlosLima
Solution Luke 42221 Posted July 5, 2019 Solution Posted July 5, 2019 Resume data is based on movie db IDs so currently this is the way things are done. You could always merge them and use our multi version features. 1
