uthall 3 Posted July 4, 2019 Posted July 4, 2019 Hi, Bought an android tv x96 max, and install the Emby for Android tv app from the play store. When I start Emby, and select the server, the screen goes black and then hangs repeatedly. Don’t have this issue on my Nvidia sheild. Is there an issue with the app and the x96?
ebr 16338 Posted July 4, 2019 Posted July 4, 2019 What version of Android is it? If it is 9.0 the latest beta may fix it.
uthall 3 Posted July 5, 2019 Author Posted July 5, 2019 (edited) 8.1 But i dont belive it runs google Android TV either, as its interface is different to my Shield. Can i load up google Android TV somehow? How do I get the 9.0 beta installed too? Edited July 5, 2019 by uthall
mastrmind11 722 Posted July 5, 2019 Posted July 5, 2019 nope, those knock off boxe run a hacked version of atv. True ATV is not in the wild as an apk, which is why there are certified boxes like the Shield.
ebr 16338 Posted July 5, 2019 Posted July 5, 2019 Did you try our beta app (linked above)? If that still doesn't work then the box may just not be compatible.
mnmpeanuts 0 Posted July 5, 2019 Posted July 5, 2019 Ill try it out. I just signed up, but how do i link to my google account i use on the tv box?
roterblauwal 0 Posted May 16, 2020 Posted May 16, 2020 (edited) Hey together, seems no solution for this so far? I was lurking in the dark a bit until I came across the same or similar problem (so far I am a happy user). I have an x96 Andorid TV Box as well (Android 9) and for me the app crashes after trying to login: I can start the app, it finds the server in the local network, I can choose a user, enter password and then it tries to load until it crashes...Already tried the beta version and I tried to connect via DynDns and emby connect. Same results. Edit: Also tried the regular Android App, which works but I can't use the remote control of the box. Is there anything I could try or looking forward to? I can provide the logs from server if this helps, it looks like this: 2020-05-16 20:34:44.904 Info Dlna: No matching device profile found. The default will need to be used. DeviceDescription: FriendlyName:AS-X96miniP[DMR] Manufacturer:Amlogic ManufacturerUrl: ModelDescription:AirScreen MediaRenderer ModelName:AirScreen MediaRenderer ModelNumber:1 ModelUrl:http://www.ionitech.cn/ SerialNumber: 2020-05-16 20:34:44.905 Info Dlna: DLNA Session created for AS-X96miniP[DMR] - AirScreen MediaRenderer 2020-05-16 20:36:17.830 Info App: Udp message sent to 192.168.178.73:51164 2020-05-16 20:36:17.841 Info App: Udp message sent to 192.168.178.73:51164 2020-05-16 20:36:18.945 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:36:18.948 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 3ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:36:19.029 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:36:19.034 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 4ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:36:19.368 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/Users/Public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:36:19.377 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 9ms. http://192.168.178.76:8096/emby/Users/Public?format=json 2020-05-16 20:36:19.935 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/Users/b5afa6800cf8454998f91e20ffeb90c5/Images/Primary?Accept=webp&EnableImageEnhancers=true&MaxHeight=370&Tag=25aac2de9ad25660265a4c6ae55514ac. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:36:19.941 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 6ms. http://192.168.178.76:8096/emby/Users/b5afa6800cf8454998f91e20ffeb90c5/Images/Primary?Accept=webp&EnableImageEnhancers=true&MaxHeight=370&Tag=25aac2de9ad25660265a4c6ae55514ac 2020-05-16 20:37:17.519 Info App: Udp message sent to 192.168.178.73:53305 2020-05-16 20:37:17.536 Info App: Udp message sent to 192.168.178.73:53305 2020-05-16 20:37:18.571 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:37:18.575 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 3ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:37:18.643 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:37:18.645 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 2ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:37:18.733 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/Users/Public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:37:18.739 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 6ms. http://192.168.178.76:8096/emby/Users/Public?format=json 2020-05-16 20:37:27.741 Info App: Udp message sent to 192.168.178.73:38759 2020-05-16 20:37:27.750 Info App: Udp message sent to 192.168.178.73:38759 2020-05-16 20:37:28.783 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:37:28.785 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 3ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:37:28.831 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/system/info/public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) 2020-05-16 20:37:28.833 Info HttpServer: HTTP Response 200 to 192.168.178.73. Time: 2ms. http://192.168.178.76:8096/emby/system/info/public?format=json 2020-05-16 20:37:28.942 Info HttpServer: HTTP GET http://192.168.178.76:8096/emby/Users/Public?format=json. UserAgent: Dalvik/2.1.0 (Linux; U; Android 9; X96mini_P Build/PPR1.180610.011) Cheers & thanks for looking in to this Edited May 16, 2020 by roterblauwal
Luke 42246 Posted May 16, 2020 Posted May 16, 2020 Edit: Also tried the regular Android App, which works but I can't use the remote control of the box. Hi there, what version of the app did you try?
roterblauwal 0 Posted May 17, 2020 Posted May 17, 2020 Emby for Android TV: Version 1.8.00g ==> Crashes with login Emby for Android: Version 3.1.22 ==> Works, but can't be controlled with the remote (works fine if I connect a mouse)
Luke 42246 Posted May 17, 2020 Posted May 17, 2020 Emby for Android: Version 3.1.22 ==> Works, but can't be controlled with the remote (works fine if I connect a mouse) It can if you enable TV mode in the app's display settings.
roterblauwal 0 Posted May 17, 2020 Posted May 17, 2020 It can if you enable TV mode in the app's display settings. Thank you never noticed that. Seems to work fine ... only performance with the app on that device is not that great. Full HD movies and live streams are a bit stuttering. I guess that would be not the issue with the andorid for tv app. Anyway I am fine with it (I have another app for iptv wich works better) . Thanks again.
pellimark 1 Posted June 4, 2020 Posted June 4, 2020 I have the same isssue on A95Max +, did you find a solution?
Luke 42246 Posted June 4, 2020 Posted June 4, 2020 I have the same isssue on A95Max +, did you find a solution? Hi there, did you see my previous response?
pellimark 1 Posted June 4, 2020 Posted June 4, 2020 Yes i saw it, yes it kind of works, however playback is not smooth moslty on 4k videos
pellimark 1 Posted June 4, 2020 Posted June 4, 2020 I mean same as the other person said, playback stutters
