keith2045 7 Posted July 3, 2019 Posted July 3, 2019 I've decided to try and run emby sever in a docker container on a linux host. Everything is going well except i'm unable to play 1 video. I've tested a few others and they play just fine but this one wont start at all. I've tried playing it using the fire app and the web interface. It did play fine when i had the emby server installed directly on linux. I've attached a few of the ffmpeg log files. Any thoughts? ffmpeg-transcode-1.txt ffmpeg-transcode-2.txt ffmpeg-transcode-3.txt
Luke 42246 Posted July 3, 2019 Posted July 3, 2019 Hi, that's strange as there's nothing obvious here. As a test, if you disable throttling under the server dashboard transcoding section, does that make any difference?
keith2045 7 Posted July 3, 2019 Author Posted July 3, 2019 (edited) No luck, same issue. I did notice on the dashboard it looks like it is playing as the time is shown (except the length of the video is not displayed). It never gets past 7 seconds though Attached is another log if it is helpful ffmpeg-transcode-4.txt Edited July 3, 2019 by keith2045
Luke 42246 Posted July 3, 2019 Posted July 3, 2019 That's very strange. In the coming days we'll be releasing 4.2. Can you please try again with that once available? Thanks.
