eraser8 55 Posted July 2, 2019 Posted July 2, 2019 (edited) Hi guys, I think there is a problem when trying to organize some TV series. Just take a look at the log and you could see that the system is trying to read an fr-ca.xml file in his cache but it previously download a fr.xml file.... so, Maybe not too long to fix for you, anyway, here is the log: Thanks embyserver.txt Edited July 2, 2019 by eraser8
eraser8 55 Posted July 2, 2019 Author Posted July 2, 2019 Can you please discuss the problem? Thanks. Sure Luke, It is really simple. I have some TV series in my temp directory (to be organized) and when I run the organization, it gives me errors. So the move didn't work and all episode name are in red.
eraser8 55 Posted July 2, 2019 Author Posted July 2, 2019 In the log: System.IO.FileNotFoundException: System.IO.FileNotFoundException: Could not find file "/var/db/emby-server/cache/tvdb/359978/fr-ca.xml" File name: '/var/db/emby-server/cache/tvdb/359978/fr-ca.xml' and like I said, the name is in red and "There is no provider data found". Thanks
Solution Luke 42255 Posted July 2, 2019 Solution Posted July 2, 2019 Ok please try the tvdb update that i'm pushing. thanks. 1
eraser8 55 Posted July 2, 2019 Author Posted July 2, 2019 Ok please try the tvdb update that i'm pushing. thanks. Great! I did install the 1.0.13 TVDB and it works now!! Great thanks Luke!
