jackandjohn 11 Posted July 2, 2019 Posted July 2, 2019 Surprised I have not seen this anywhere else, hopefully it’s not just a “me thing”. Sometimes I fall asleep to a show or movie, and when I wake up Emby has long-finished the video, but the screen is still on. I have Emby autoplay off, and device Auto-lock set to 2 minutes. iPad Air 2 (cellular) iOS 12.1 Latest version of Emby
Luke 42242 Posted July 2, 2019 Posted July 2, 2019 Hi there, would you like to try the beta and see if that still has this issue?
jackandjohn 11 Posted July 4, 2019 Author Posted July 4, 2019 Unfortunately the issue is still present in the beta. The process I went through: - Delete the app to clear settings - Install the App Store version to "restore purchase" for the video playback - Install the beta over the App Store version - Test playback in my account (screen stayed on until I shut it off manually at 15min after playback was finished) - Test playback in the guest account (first disabled auto-play next item) (same symptom)
Wynter 3 Posted September 24, 2019 Posted September 24, 2019 Has this issue been resolved? This issue occurs on all the iOS devices I have (all on iOS 12.4.1 or 13 and the newest version of Emby for iOS).
jackandjohn 11 Posted September 24, 2019 Author Posted September 24, 2019 Confirmed: Still happening for me, even on betas I’ve unfortunately had to resort to Plex for night-time watching
Wynter 3 Posted September 25, 2019 Posted September 25, 2019 Confirmed: Still happening for me, even on betas I’ve unfortunately had to resort to Plex for night-time watching I'm a little astounded that this hasn't been corrected... the original post is months old and it is obviously not hard to reproduce. I try so hard to use and recommend Emby but these are the kinds of issues that make it difficult. I have a lifetime premier membership and over the last couple years I've been using Plex because of issues like this... every so often I come back and test things out and find some issue. This time everything seemed good and I have been using it for a short time but this, even though it is a minor issue will probably push me back to Plex and for what? An issue that has been noted months and months ago.
Luke 42242 Posted September 25, 2019 Posted September 25, 2019 We are looking into this. Thanks fore reporting.
Luke 42242 Posted October 1, 2019 Posted October 1, 2019 This will be resolved for the next update to the app. Thanks.
Solution Wynter 3 Posted October 5, 2019 Solution Posted October 5, 2019 Works perfectly now... thanks! I’ve been switching everything back to Emby from Plex and with that last glitch fixed I must say that things are quite solid now... the one area that could use some work is the offline downloads, it works but could use some fine tuning. 1
