Apologies if this has been brought up before.
I'm looking for a decent software to monitor my server temp, cpu, etc.. The Gigabyte software is too resource intensive for my liking. Just looking for something lite that will just preform the basic monitoring. Nothing too fancy.
Thanks
Guest asrequested
I don't use it all anymore. But I just used the free version. Now I use Stablebit, and my Corsair fan controller. You said you wanted something lite.
Swynol
take a look at pulseway you can remotely monitor stats. otherwise cpuid or hw monitor.
or if you want a really customizable option look at prtg.
Spaceboy
prtg ftw
Guest asrequested
Thanks
I don't think PRTG fits that description :)
Edited by Doofus
