classic57b 0 Posted June 30, 2019 Posted June 30, 2019 Hello, when I go into EMBY through ROKU and select "Recordings" the thumbnail layout is 3 wide and the green dot indicating the # of shows unwatched is to the right of the thumbnail. I just recently added "RecordedTV" and when I select it the thumbnail layout is 6 wide and the green dot is overlayed on the thumbnail. Here's the strange part. If I select the "RecordedTV" and navigate to the thumbnail layout (it will be 6 wide) and then back out of it and go to the "Recordings" tab the thumbnail layout is 6 wide with the green dots as an overlay to the thumbnails. Then if I back out of EMBY, and go back into "Recordings" the thumbnail layout is back to 3 wide. I want it to be 6 wide all the time. Is there a setting I missed that will make it 6 wide all the time?
speechles 2062 Posted June 30, 2019 Posted June 30, 2019 (edited) Thanks for the report. This will be addressed in a future update. We are fixing this and already through most of the process. The smaller images on the homescreen for LiveTV will also be resolved. Any and all aspect-ratio issues will be resolved. There will also be other areas we improve. Stay tuned. Also are you on the Emby Beta for Roku? If not this is our pre-production branch and you may want to be on the Beta app. Edited June 30, 2019 by speechles
classic57b 0 Posted June 30, 2019 Author Posted June 30, 2019 Thanks for the quick response. Yes, I am on Emby BetaA for Roku. You guys are doing great.
