nightflyer00 4 Posted June 30, 2019 Posted June 30, 2019 Hi Guys, 2 Items here. First I have an older Readynas Pioneer Pro that has had a CPU and RAM upgrade and been upgraded to the latest OS6. I had issues with all versions of the Emby server I installed with the server shutting down within a minute of starting every time. I installed the latest Beta yesterday and that works fine which is great. New issue. System scans and adds my TV shows no problem at all. When I add my Movie folder it finds nothing. Both folders are on the same NAS. The movie folder is setup as /movies/Title Folder/videofile.mkv Can't figure out why it won't read the files. Can PM log if needed. Thanks 4
Luke 42237 Posted June 30, 2019 Posted June 30, 2019 Hi there, can you please go over a specific example? What libraries have you created in Emby library setup, and using what folders? Thanks.
